Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
CRC8 (Dallas 1-wire)
PostPosted: Wed Mar 08, 2006 8:11 am     Reply with quote
It is already hidden in the forum somewhere, but I like this efficient implementation of a CRC8 algorithm so much I thought it best to post it here as well.
// Calculate crc8 checksum
// This is the checksum as used in the Dallas One Wire protocol.
// Advantage of this checksum over other crc's is that because of a pecularity
// of this specific polynomial it allows bytewise processing without bit
// shifting.  It's very fast, small and uses no RAM.
// Based on:        Maxim Application Note 27,
//                  http://www.maxim-ic.com/appnotes.cfm/appnote_number/542
// Original C code: T. Scott Dattalo
//                  http://www.dattalo.com/technical/software/pic/crc_8bit.c
// Optimized by:    Dirk Van den Berge (dvdb)
//                  donated to the CCS-forum 12-jan-2004
//                  http://www.ccsinfo.com/forum/viewtopic.php?t=17170
int8 Calc_Crc8(int8 *Buffer, int8 byte_cntr)
  int8 crc=0;
#ASM
  //copy pointer to pointer register (CCS doesn't support lfsr assembly instruction)
  movff  Buffer,FSR0L
  movff  &Buffer+1,FSR0H
loop:
  movf POSTINC0,w   // load w with next databyte
  xorwf crc,f       // xor with accumulated crc (accumulated crc is no longer valid now)
  movlw 0           // w will accumulate the new crc
  btfsc crc,0
   xorlw 0x5e       // could also be iorlw
  btfsc crc,1
   xorlw 0xbc
  btfsc crc,2
   xorlw 0x61
  btfsc crc,3
   xorlw 0xc2
  btfsc crc,4
   xorlw 0x9d
  btfsc crc,5
   xorlw 0x23
  btfsc crc,6
   xorlw 0x46
  btfsc crc,7
   xorlw 0x8c
  movwf crc         // store accumulated crc
  decfsz byte_cntr,f
  goto loop         // next databyte
                    // done, crc is in w
  movwf crc         // store in result
#ENDASM
  return crc;
jonowoodhouse
crc8 - assembler c crc routine
PostPosted: Mon Feb 12, 2007 11:54 am     Reply with quote
Hi
Firstly, to Dirk & the others - thanks very much for this code. It's been really useful. Smile
Below please find a variation that will run for both the PIC16 (PCM) and PIC18 (PCH) PIC chips, and allows you to pass in the initial CRC value. (Make this zero if you don't want to build on a previously calculated value).
[Also, you may not need the first section (which sets up some #defines and #locates) if you have already done this, or are including in some inc file.]
// Minor tweaks by: Jono Woodhouse (jonowoodhouse) and ckielstra
//                  http://www.ccsinfo.com/forum/viewtopic.php?t=26264
// Setup FSR and INDF
#if defined(__PCM__)                     // For example (and tested on) PIC16F74, PIC16F887
   #locate FSR = 0x0004
   #locate INDF = 0x0000
#elif defined(__PCH__)                  // For example (and tested on) PIC18F4520
   #define FSR0 0x0000
   #define INDF0 0x0FEF
   #define POSTINC0  0x0FEE
   #locate FSR0L = 0x0FE9
   #locate FSR0H = 0x0FEA
   #locate STATUS = 0x0FD8
#else
   #Error You need to setup the above for your PIC Chip
#endif
// This is the crc8 function for use on the PIC16 and PIC18 etc. microprocessors
unsigned int8 crc8_pic(unsigned int8* p_data, unsigned int8 p_datalength, unsigned int8 crc) {
   #ASM
         movf   p_data, W               // copy pointer to w reg..
         movwf  FSR                     // ..to pointer register
         movff   p_data, FSR0L         // copy low byte of pointer to low byte of pointer register 0..
         movff   &p_data+1, FSR0H      // copy high byte of pointer to high byte of pointer register 0..
      #else
      #endif
      loop:
            movf   INDF, W            // load w with next databyte
            incf FSR                  // do a 8-bit increment - increment indirection register to point to next databyte - for the next time
            movf   POSTINC0, W      // load w with next databyte and increment indirection register to point to next databyte - for the next time
         #else
         #endif
         xorwf crc, F               // xor with accumulated crc (accumulated crc is no longer valid now)
         btfsc crc, 0
         btfsc crc, 1
            xorlw 0xbc
         btfsc crc, 2
            xorlw 0x61
         btfsc crc, 3
            xorlw 0xc2
         btfsc crc, 4
            xorlw 0x9d
         btfsc crc, 5
            xorlw 0x23
         btfsc crc, 6
            xorlw 0x46
         btfsc crc, 7
            xorlw 0x8c
         decfsz p_datalength, F
      movwf crc                     // done, crc is in w - now store it in result (crc)
   #ENDASM
   return(crc);
I've tested this on a PIC16F74, PIC16F884, PIC16F887 & PIC18F4520.
Cheers
Jono Woodhouse
PostPosted: Wed Jun 15, 2011 7:15 am     Reply with quote
I like Jono's version because it is more flexible than the original posting. I made a few minor tweaks to make better use of the newer compiler options (tested in v3.249 and 4.077):
- For the PIC18 the LFSR instruction is supported from v3.249 and up. This saves 4 bytes.
- Added the GETENV directive to get the addresses for the Special Function Registers instead of using hard coded values.
- Renamed p_datalength to datalength as it is not a pointer.
// Setup Index Register locations (FSR and INDF)
   #byte FSR = GETENV("SFR:FSR")
   #byte INDF = GETENV("SFR:INDF")
   #byte POSTINC0 = GETENV("SFR:POSTINC0")
#else
#endif
unsigned int8 Calc_Crc8(unsigned int8* p_data, unsigned int8 datalength, unsigned int8 crc)
   #ASM
         movwf  FSR                 // ..to indirection register
         lfsr   0, p_data           // copy pointer to indirection register 0
      #else
      #endif
      loop:
            movf  INDF, W           // load W with next databyte
         #else
         #endif
         movlw  0                   // W will accumulate the new crc
         btfsc crc, 0
         btfsc crc, 1
         xorlw 0xbc
         btfsc crc, 2
         xorlw 0x61
         btfsc crc, 3
         xorlw 0xc2
         btfsc crc, 4
         xorlw 0x9d
         btfsc crc, 5
         xorlw 0x23
         btfsc crc, 6
         xorlw 0x46
         btfsc crc, 7
         xorlw 0x8c
         decfsz datalength, F
      movwf crc                     // done, crc is in W - now store it in result (crc)
   #ENDASM
   return crc;
pozzari
Don't work with pic12f675
PostPosted: Sat Apr 14, 2012 12:05 am     Reply with quote
Don't work with pic12f675.
But works fine with other MCU´s.
Gabriel
PostPosted: Mon Sep 01, 2014 2:24 pm     Reply with quote
Can you post a small sample program on how to use this?
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Tue Sep 09, 2014 4:22 pm     Reply with quote
Turns out that for PCH there are still problems with the LFSR assembly instruction. It is not loading the pointer but the address of the registers holding the pointer.
Here is a fixed version where the FSR register is loaded using plain C code. Easier to read and portable for both PCM and PCH.
Also added example code.
#include <18F458.h>
#FUSES HS, NOWDT, PUT, NOLVP
#device PASS_STRINGS=IN_RAM
#use delay(clock=4MHz)
#include <stdlib.h>     // for strlen()
// Code downloaded from: http://www.ccsinfo.com/forum/viewtopic.php?t=26264
//                  http://www.maximintegrated.com/en/app-notes/index.mvp/id/27
// 2004-01-12: Dirk Van den Berge (dvdb)
//    - Optimizations and CCS conversion.
// 2007-02-12: Jono Woodhouse (jonowoodhouse)
//    - Will now run for both the PIC16 (PCM) and PIC18 (PCH) PIC chips.
//    - Allow to pass in the initial CRC value. (Make this zero if you don't want
//      to build on a previously calculated value).
// 2011-06-15: C. Kielstra
//    - Save 4 bytes for PCH by using the LFSR instruction.
//    - Made more flexible by using the GETENV directive to get the addresses for
//      the Special Function Registers instead of using hard coded values.
//    - Renamed p_datalength to datalength as it is not a pointer.
// 2014-09-09: C. Kielstra
//    - Fix: On PIC18 loading the FSR register through the LFSR assembly command
//      didn't work. Now replaced by a line of C code that is easier to read and
//      works both on PIC16 and PIC18.
//    - Added example program.
#elif defined(__PCH__)                  // For example (and tested on) PIC18F458
   #word FSR = GETENV("SFR:FSR0L")
#else
   #Error You need to setup the above for your PIC chip
#endif
unsigned int8 Calc_Crc8(unsigned int8 *p_data, unsigned int8 datalength, unsigned int8 crc)
   FSR = p_data;                    // Load the indirection register
   #ASM
      loop:
         #else
         #endif
         btfsc crc, 0
         btfsc crc, 1
         xorlw 0xbc
         btfsc crc, 2
         xorlw 0x61
         btfsc crc, 3
         xorlw 0xc2
         btfsc crc, 4
         xorlw 0x9d
         btfsc crc, 5
         xorlw 0x23
         btfsc crc, 6
         xorlw 0x46
         btfsc crc, 7
         xorlw 0x8c
   #ENDASM
   return crc;
   int8 crc;
   int8 length;
   char message[] = "Hello world.";
   // Example when you have to calculate the CRC over a message in one go.
   length = strlen(message);
   crc = Calc_Crc8(message, length, 0);
   printf("CRC-1 = %u\n", crc);
   // Example when you have to calculate the CRC in multiple steps.
   crc = 0;             // Set the CRC start value. 1-wire protocol uses 0, other protocols often start with 0xFF.
   crc = Calc_Crc8("Hello",  5, crc);
   crc = Calc_Crc8(" ",      1, crc);
   crc = Calc_Crc8("world.", 6, crc);
   printf("CRC-2 = %u\n", crc);
// Generated output:
// CRC-1 = 105
// CRC-2 = 105
Gabriel
PostPosted: Wed Sep 10, 2014 7:59 am     Reply with quote
Thanks for the sample program!
Kind regards,
G.
