asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
| Beta Testers wanted - Ethernet Bootloader for ENC28J60 |
Posted: Mon Mar 06, 2006 3:23 am |
I am looking for Beta Testers for an Ethernet Bootloader for the ENC28J60 used with any of the following PICs PIC18F242 / PIC18F252 / PIC18F442 / PIC18F452 / PIC18F2525 / PIC18F2620 / PIC18F4525 / PIC18F4620. For those interested I have a reference design (no PCB available) based on the PIC18F2620 which also supports an SD Card, Serial Port, Status LEDs and a 25256 FRAM.
If you are interested in testing the bootloader and already have a suitable hardware platform let me know. The bootloader includes some diagnostics so if you have a hardware platform that is not yet debugged this may be of interest to you.
I have added support for the EDTP Frame Thrower Plus based on the PIC18F8621 but this has not yet been tested (I don't have one).
Updated 8th March 2006 - added support for the CCS Embedded Ethernet Development board based on the PIC18F4520 and ENC28J60 but this has not yet been tested (I don't have one). _________________ Regards, Andrew
Mark
Posted: Mon Mar 06, 2006 7:40 pm |
Hi Andrew,
My ENC28J60 is connected to an 18F6720 but I'd be glad to be a beta tester. |
asmallri
Posted: Mon Mar 06, 2006 8:04 pm |
| Mark wrote: | Hi Andrew,
The Ethernet bootloader does currently not support PICs with program memory > 64K. I intend to add this capability shortly but not until after this round of testing. I will let you know when this is ready. _________________ Regards, Andrew
bretesq
Posted: Tue Mar 07, 2006 2:42 pm |
Hey Andrew,
I have a ENC28J60 along with a PIC18F452. I am having some problems with the wiring, but I would be more than happy to test it for you. |
bretesq
Posted: Tue Mar 07, 2006 2:48 pm |
| Also, I have all the hardware you listed the reference diagram for. The main issue of mine is the ethernet transformer. I have salvaged one off of an old NIC, along with its 25mhz crystal. I am very interested in getting this setup to work. Thanks |
asmallri
Posted: Wed Mar 15, 2006 8:08 am |
Hi Mark,
I am currently adding support for the 18F6720. Could you send me the schematic for your board.
Regards, Andrew _________________ Regards, Andrew
