Bart
| Who has MMC FAT16 WRITE example ? |
Posted: Wed Nov 09, 2005 4:41 pm |
and is able to share it ?
I know there is code available in the Code Library concerning FAT16 and MMC but I can't find (on the entire forum) an example on writing a textfile.txt to a MMC.
Reading files works fine with http://www.ccsinfo.com/forum/viewtopic.php?t=21721 and it has even the possibility to write but I can't understand how I should do.
I know there is also FAT32 code but as I have for the moment only 32Mb card, I want to use this card.
Any help is welcome !
Thanks. _________________ I like Skype (www.skype.com), my username is BplotM |
Bart
Posted: Mon Nov 14, 2005 2:53 pm |
Second and last try : nobody ? _________________ I like Skype (www.skype.com), my username is BplotM |
Coach Guest
| Read example, please |
Posted: Thu Nov 24, 2005 5:28 pm |
Hi Bart
I need to also work with MMC in FAT16.
I've a 18LF2550 and 32MB MMC.
I have connected the SPI directly to the MMC, with +3,3V.
Please, you can post a small example of reading for file.txt?
More ahead I will need also to make the writing of the file. But first I must be able to make the reading.
I need an external memory?
I do not use the serial port in my application, then I have eliminated of driver all the code referring to the serial port.
I hope that somebody can help me, I will try to contribute in everything what can.
A greeting to all and thank you very much in advance.  |
Bart
Posted: Thu Nov 24, 2005 5:36 pm |
Hello Coach,
Please create a account in the forum and login.
So I will be able to sent you PM.
Best greetings. _________________ I like Skype (www.skype.com), my username is BplotM |
kender
Coach
Posted: Thu Nov 24, 2005 6:13 pm |
Hello again.
Thanks to answer so fast
I already registered myself, I did not do it before because it thought that it was not necessary
Thanks Kender, but already it knew that product previously.
The problem is my under budget to make the project.
But it is thanked for anyway
A greeting to all. |
King Virus
| Help me Bart ! |
Posted: Thu Mar 02, 2006 8:58 am |
| Bart wrote: | Hello Coach,
Best greetings. |
Hi Bart !
Could you also send me this PM ? I´m verry interested to do some crazy stuff with fat32 !
Thanks ! |
