Help with a stuck IO Pin
jfk1965
PostPosted: Wed Feb 15, 2006 6:41 am     Reply with quote
Hi
I'm using the 16F818 with Compiler version 3.217.
My problem always arises when I try to use pin B3 as an output, it won't change state when programmed. Until now I have got around this by switching to another spare pin which has worked fine. When programmed to go high the pin always stays low and won't alter state at all.
I aways program all pins to a known state at powerup (usually all low) by using the standard output_low (Pin_B0) through to pin B7 command. All other pins will switch to high when programmed to using the standard output_high(Pin_B0) command except for pin B3
I now have an application coming up that needs all pins as outputs so I need to overcome this problem.
Has anyone got any ideas what I'm doing wrong?
thanks in advance
JFK
Humberto
PostPosted: Wed Feb 15, 2006 7:17 am     Reply with quote
Without knowing your code it is difficult to help you, so I just can guess something like
Pin_B3 is usually shared with the ICSP as enable pin.
Does your code has the directive #ICD=TRUE ?
Humberto
jfk1965
PostPosted: Wed Feb 15, 2006 8:17 am     Reply with quote
No I don't use the ICD here's a simple program that I used earlier today to test it out you will see I switched the redled output to Pin B0 from B3 to get it to work.
#include <touch.h>
#include <stdlib.h>
//Lithium Ion charger
//Revision 1.0
//written on compiler version 3.217
//tested on compiler version 3.217
#define timer 210
#define vconnect 452
#define vmin 258   //minimum battery voltage 10V
#define imin 63    //switch over current from hi V to lo V
#define ledred (Pin_B0)
#define ledgreen (Pin_B2)
#define onoff (Pin_B6)
long int vbatt,ibatt,minute;
long tick;
void RedLedFlash()
   output_high ledred;
   delay_ms(200);
   output_low ledred;
   delay_ms(200);
void Reset()
   Output_low onoff;
   Output_low ledred;
   Output_low ledgreen;
   vbatt=0,ibatt,minute=0,tick=0;
#int_RTCC
void RTCC_isr()
   tick++;
      if(tick == 15000)
            minute++;
            tick=0;
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_16);
   goto start;
charged:
   set_adc_channel(0);
   output_low onoff;    //switch charger off
   output_high ledgreen; //change led to show charged
   output_low ledred;
   disable_interrupts(global);
   do
   vbatt = read_adc();
   while(vbatt > vmin);
start:
   Reset();
   do               //test for battery connected
      set_adc_channel(0);
      delay_us(100);
      vbatt = read_adc();
     RedLedFlash();
   while (vbatt < vmin);
   output_high onoff;   //switch charger on and indicate charging
   output_high ledred;
   enable_interrupts(global);
 do                  //loop until battery disconnected or charged
   vbatt = read_adc();
    if (vbatt >= vconnect) goto charged;
   set_adc_channel(2);
   ibatt = read_adc();
    if(ibatt < imin) goto charged;
   if(minute > timer)goto charged;
   set_adc_channel(0);
 while (1);
drh
PostPosted: Wed Feb 15, 2006 8:24 am     Reply with quote
Look at your #FUSES statement.
Change LVP to NOLVP.
David
