| usart config at runtime |
Posted: Tue Feb 14, 2006 10:30 am |
I am trying to change the usart configuration (PIC16F913) at run time
reading the new settings from a register.
I can modify the baud rate but not the parity.
Here the function I use.
How can I do it ?
void configUart(void)
unsigned char br_n = 0;
unsigned char pr_n = 0;
br_n = reg[BR_ADDR] ;
pr_n = reg[PAR_ADDR] ;
switch (pr_n)
case 0:
#use rs232(parity=n,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_C5,errors)
case 1:
#use rs232(parity=e,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_C5,errors)
case 2:
#use rs232(parity=o,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_C5,errors)
default:
#use rs232(parity=e,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_C5,errors) // Default Parity Even
switch (br_n)
case 0:
set_uart_speed (4800);
case 1:
set_uart_speed (9600);
case 2:
set_uart_speed (19200);
case 3:
set_uart_speed (28800);
case 4:
set_uart_speed (33600);
case 5:
set_uart_speed (57600);
default:
set_uart_speed (9600); // Default Baud Rate 9600
Alex N
Posted: Tue Feb 14, 2006 10:56 am |
| Is it enough for your task to make some output streams with different settings and switch between them at runtime? |
gian793
Posted: Tue Feb 14, 2006 3:46 pm |
| After calling my function I need to make output streams and also to read from uart. I think there's something wrong in using #use rs232 statement but... |
Posted: Tue Feb 14, 2006 3:54 pm |
The #use rs232() statement creates one instance of the CCS
library code, based on the parameters that you specify.
It doesn't change parameters at runtime in a single instance
of the code, which is what you're hoping it does. |
Posted: Wed Feb 15, 2006 5:07 am |
o.k the code I have written was wrong.
Any suggest to cope with the problem of changing the parity at run time?
Can I write a routine that do it?
The only way is to avoid getc() and putc() functions and handle the uart registers directly? |
Alex N
