error "A numeric expression must appear here"
mle
PostPosted: Tue Jun 24, 2003 3:04 pm     Reply with quote
hello,
I'm having problems trying to do some simple arithmetic. I have the following piece of code that is giving me errors:
void write1wire(int byte){
int i; //counter
int bit; //holds value of last bit in byte
bit=byte\%2; //********ERROR HERE*********//
For (i=1; i<=8; i++){
if (bit == 1){
output_low(DQout);
delay_us(1);
output_high(DQout);
delay_us(60);
else {
output_low(DQout);
delay_uS(60);
output_high(DQout);
byte = byte/2; //********ERROR HERE*********//
I get an error saying "A numeric expression must appear here" at the both errors. Does anyone know why this is?
Thank you,
mle
___________________________
Original Post ID: 144515539
Re: error "A numeric expression must appear here"
PostPosted: Tue Jun 24, 2003 3:43 pm     Reply with quote
:=hello,
:=I'm having problems trying to do some simple arithmetic. I have the following piece of code that is giving me errors:
:= bit=byte\%2; //********ERROR HERE*********//
"byte" is a defined keyword for CCS. You shouldn't use it.
Look in the 16F877.h file (or any other header file)
and you'll see it defined as an alias for "int".
Original Post ID: 144515540
