cfernandez
| Asynchronous Serial Routine |
Posted: Sun Feb 05, 2006 9:48 am |
I have some problems with the software uart and I want to use other routine that CCS, somebody write serial routine for no UART ports ?.
Is possible that post this?
Thank you very much!! |
rwyoung
Posted: Sun Feb 05, 2006 7:32 pm |
Go look at http://www.piclist.com/techref/microchip/rs232.htm. Probably all in assembly but from that you can either work backwards or re-code as in-line.
Also http://www.pic101.com/mcgahee/ is well worth a visit. Fr. Tom McGahee has a very well documented set of RS232 functions. _________________ Rob Young
Freddie
Posted: Fri Feb 10, 2006 5:10 pm |
In CCS you can use any pin as a serial port, regardless if that pin has a hardware UART port on it. It works great. I use it all the time..
Look in the manual, but you want to do something like this:
#define ToPC PIN_C6 //your pins here
#define FromPC PIN_C7 //your pins here
#use rs232(BAUD=9600, XMIT=ToPC, RCV=FromPC, STREAM=serialPC)
printf(serialPC,"TestBoxFound\r\n");
Posted: Fri Feb 10, 2006 5:16 pm |
He doesn't want to use the CCS library code:
| Quote: | | I want to use other routine that CCS |
Posted: Sat Feb 11, 2006 10:45 am |
Though it would be interesting to know 'why not' The CCS code, except for a few problems on specific chips/versions, is pretty good.
Freddie
