trying to interface lcd screen
mle
PostPosted: Tue Jun 24, 2003 11:14 am     Reply with quote
I am trying to write a program to test a 2x24 lcd screen using a pic 16f877. The pin connections are as follows:
// A1 enable
// A3 rs
// Gnd rw
// D0 D4
// D1 D5
// D2 D6
// D3 D7
When I run the program, I get a bunch of garbage on the screen.
This is the entire program
// As defined in the following structure the pin connection is as follows:
// A1 enable
// A3 rs
// Gnd rw
// D0 D4
// D1 D5
// D2 D6
// D3 D7
// LCD pins D0-D3 ,r/w are not used and PIC B3 is not used.
#include <16F877.h>
#use delay(clock = 4000000)
#BIT LCD_EN = 0x05.1 //maps the enable bit to RA1
#BIT LCD_RS = 0x05.3 //maps the rs bit to RA3
#BYTE PORTA = 0x05 //PORTA IS ADDRESS 5
#BYTE PORTD = 0x08 //PORTD IS ADDRESS 8
#define LCD_STROBE ((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void lcd_write(char c)
PORTD = (PORTD & 0xF0) | (c >> 4);
LCD_STROBE;
PORTD = (PORTD & 0xF0) | (c & 0x0F);
LCD_STROBE;
delay_us(40);
// Clear and home the LCD
void lcd_clear(void)
LCD_RS = 0;
lcd_write(0x1);
delay_ms(2);
/* write a string of chars to the LCD */
void lcd_puts(char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
void lcd_putch(char c)
LCD_STROBE;
LCD_STROBE;
delay_us(40);
/* Go to the specified position*/
void lcd_goto(char pos)
LCD_RS = 0;
lcd_write(0x80+pos);
/* initialize the LCD - put into 4 bit mode */
void lcd_init(void)
LCD_RS = 0; // write control bytes
delay_ms(15); // power on delay
PORTD = (PORTD & 0xF0) | (0x03); //ATTENTION
LCD_STROBE;
delay_ms(5);
LCD_STROBE;
delay_us(100);
LCD_STROBE;
delay_ms(5);
PORTD = (PORTD & 0xF0) | (0x20); // set 4 bit mode
LCD_STROBE;
delay_us(40);
lcd_write(0x28); // 4 bit mode, 1/16 duty, 5x8 font
lcd_write(0x08); // display off
lcd_write(0x0F); // display on, blink curson on
lcd_write(0x06); // entry mode
void main(){
/*----------configure all the ports-------*/
Set_Tris_A(0x00); //set port A to outputs
Set_Tris_B(0x33); //make RB5, RB4(BUTTONS),
//RB1 (DQin) and RB0(pulse in) inputs
Set_Tris_C(0xD7); //RC7, RC6 (for Hserin/Hserout), RC4(RTC),
//RC2, RC1, RC0 inputs
Set_Tris_D(0x00); //set port D to outputs
Set_Tris_E(0x00); //set port E to outputs
delay_us(500);
lcd_init();
lcd_clear();
lcd_puts("Hello World");
Thanks for the help,
mle
___________________________
Original Post ID: 144515534
mle
Ignore. Working fine now
PostPosted: Tue Jun 24, 2003 11:34 am     Reply with quote
Forget it, it works!!
Original Post ID: 144515535
