cstan_02
| Reverse Polarity Protection |
Posted: Mon Feb 06, 2006 8:15 pm |
Sorry for a bit off topic.. I already have a working board for an automative app for which i intend to do some reverse polarity protection using very minimal discrete components.. Is it bad to protect the ground pin using a diode like...
diode
----|>|-----Negative terminal.
GND(Board Gnd)
And same for the POSITIVE WITH the diode reversed ??
I think that's not a good solution.. Well, no MOSFET's because working voltage is 12 to 24v. and most MOSFETs' VGS is below that.. Right ?? I don't have space for the bulky ones....
I'm looking for some cheap and simple and also taking less space solutions.... The board is already made, but whenever a reverse polarity is applied, a few tracks are burned and the board is rendered useless.. And the worse thing is that, there is a couple of antennas connected to the casing which in turn will be connected to the chassis of the vehicle. So that ground is shared as well.... I'm confused.. The experts, here are good in those things, i know .... Any Help ??
Also for the PIC 18 series, 80 pin chips, does it really help things improve if we isolate the AVdd and Vdd together with AVss and Vss ?? If then, why ?? Can I have different Vdd and AVdd levels ?? I think it's not possible. I tried it once..
Thanks.... |
kender
Posted: Mon Feb 06, 2006 8:48 pm |
| Probably the best description of protection in the automotive environment is given in the datasheet for LTC1625. See chapter "Automotive Considerations: Plugging into the Cigarette Lighter" on the page 16. |
Posted: Mon Feb 06, 2006 10:01 pm |
I've tried the circuit shown in Figure 8 (page 17). The problem is
that if there is a large over-voltage condition that lasts more than
a short time, the TVS will blow. When they blow, they actually
short out. We had a 3AG fuse, probably 3 amps, in front of the
main protection diode and that fuse blew and prevented the device
from smoking. So I cut out all the TVS devices in the remaining
boards. Fortunately, we hadn't shipped any units yet.
I'm not sure what to do for transient protection now, for a product
that plugs into a cigarette lighter. |
libor
Posted: Tue Feb 07, 2006 3:36 am |
| Quote: | | no MOSFET's because... |
...it is patented. Ref: Battery reversal protection, United States Patent 4423456
Well btw, congrats, guys for your patent system. I wonder how you can still breathe without paying for patent rights. |
Brian S
Posted: Tue Feb 07, 2006 8:00 am |
You can use a diode bridge for automatic polarity selection, with a few caveats. Connect the DC input to the "AC - AC" terminals of the bridge, the "+" bridge terminal to your circuit's + input and the bridge "-" terminal to your circuit's Gnd. You can supply the "AC-AC" terminals with DC of either polarity (or even AC), and the proper polarity will be applied to your circuit. There is no direct connection to ground while using this system, so you may have to supply some extra bypassing for RF applications, but probably not when you have an off-board antenna fed with coax.
Use a bridge of suitable current and voltage rating. Note that you'll have an extra diode drop of voltage loss with the bridge...if that's a problem, using Schottky bridge will reduce the drops.
For "fuseless" protection, follow the bridge directly with a PTC Resettable fuse, and a Sidactor or similar as a spike protector....this network is for overvoltage/overcurrent protection only, as the bridge will prevent reverse polarity. If the Sidactor fires due to voltage spike, the PTC will open briefly to limit current, then reset itself when the surge goes away. If the PTC opens due to your circuit failing, it will reset once the failure of your circuit is cleared.
I don't know the Patent Status of this system.
Good luck! |
SherpaDoug
Posted: Tue Feb 07, 2006 9:09 am |
How old is that patent? We were doing that with marine electronics in the mid 1980's so the patent is either close to expiring, or was never valid anyway. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Tue Feb 07, 2006 12:30 pm |
| Quote: | | it is patented. Ref: Battery reversal protection, United States Patent 4423456 |
That patent was filed in 1981 and granted in 1983.
I believe this is the current rule on a patent's lifespan:
| Quote: | | U.S. patents in effect on December 8, 1994, and patents issued on applications filed before June 8, 1995, will be entitled to the longer term of 17 years from the date of grant; or 20 years from the date of filing of the original application. |
So that means it has expired. |
libor
Posted: Tue Feb 07, 2006 12:49 pm |
Thanks, one less thing to worry about. I had no clue on patents' lifespan.
However I am just wondering how many other trivial solutions (like long-pressing, double clicking a push-button: US Patent No: 6,727,830 etc.) we should go roundabout in our designs just not to infringe any valid patents, and how many other trivial patents infringements will be unknowingly still left ticking in our products. |
cstan_02
Posted: Tue Feb 07, 2006 8:11 pm |
Thanks all..
We indeed had the TVS in the circuit. But, as PCM pointed out sometimes it does fail and we don't use fuses and that made the whole of the board useless.. As for the diode bridge mentioned by BrianS, it's a good solution, fail safe.. But takes some space which, unfortunately we can't afford to spare.. Four diodes is a bit big.... moreover voltage drop is a no-no here since it is a cause of concern too....
okay somebody got something else ??
Thanks.. |
Posted: Tue Feb 07, 2006 9:24 pm |
You should be able to protect your board with just a simple 1N4002 diode.
Put it inline with incoming +12v supply. The anode goes to the battery,
and the cathode goes to your voltage regulator.
| Code: | +12v
from ---->|----- To voltage regulator
battery diode |
Don't put anything on ground side.
We use Digikey p/n 1N4002DICT. http://www.digikey.com
I want to add that this diode is rated at 1 Amp, and 100 volts.
If your application uses more that 0.5 Amp, you should choose
a diode that has a higher current rating. |
cstan_02
Posted: Wed Feb 08, 2006 7:35 pm |
Thanks PCM, but that diode does exist in our board.. the problem is when you apply reverse polarity, the antenna ground is connected to the chasis of the vehicle(shared). So this diode can't protect the short circuit.. I would like to protect the ground in someway or the other.. I'm wondering how to..
Thanks. |
Posted: Wed Feb 08, 2006 8:02 pm |
Describe the antenna circuit. The only antennas that I'm aware of
are the ones for car radios. I don't think they connect to ground. |
Eugeneo
Posted: Wed Feb 08, 2006 10:53 pm |
| When all else fails uses a DC-DC isolation converter |
cstan_02
Posted: Thu Feb 09, 2006 7:57 pm |
Thanks PCM. Antenna is from my application.. The app that I'm describing has atleast two antennas connected from the board.. The casing of the unit is aluminium and the antenna connectors are attatched to it.. So thus there is a problem of the board ground directly sharing to the vehicle chasis ground.. So if reverse polarity is applied, it will burn the tracks.
Any Suggestions ??
DC-DC isolators i think should be fixed externally right ?? But here we cannot afford anything external.. And should be as small as possible so as to fit in existing board.. But also current drain is a concern here..But when everything fails and that's a good option..
Thanks.. |
Eugeneo
Posted: Thu Feb 09, 2006 8:24 pm |
I still don't understand why you can't just put a bridge rec. in there or even a single diode. Can you explain why again?
Why not just use 2 diodes on each terminal. If they connect it wrong, it will not work. |
