What is the problem?
No_Fear
PostPosted: Mon Jun 23, 2003 3:56 pm     Reply with quote
I wrote a code and it worked well(related with adc).Now i upgraded my code for 16 bit adc and it behaves weird.
#include <16F877A.h>
#include <string.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int v1;
char ON;
setup_adc_ports(ALL_ANALOG);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_d(0x00);
ON = 1;
while (1)
set_adc_channel( 0 );delay_us(50);v1 = read_adc();delay_us(50);
printf("Value:\%2X!",v1);
if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
v1=0;
This works fine but when i load this, sometimes adc results shows different values than zero when no voltage on pin.When no voltage, it gives 64-128-96 (integer values). What is wrong? / Should i research fault in my circuit?
#device adc=16 // !!! I Added tihs
#include <string.h>
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
int16 v1;
char ON;
setup_spi(FALSE);
setup_vref(FALSE);
set_tris_d(0x00);
ON = 1;
while (1)
printf("Value:\%4X!",v1);
v1=0;
___________________________
Original Post ID: 144515488
Re: What is the problem?
PostPosted: Mon Jun 23, 2003 5:04 pm     Reply with quote
:=Hi,
:=I wrote a code and it worked well(related with adc).Now i upgraded my code for 16 bit adc and it behaves weird.
It's behaving pretty much according to the chart in the
CCS manual, in the read_adc() section. (Page 130 of the
manual, or page 142 in the Acrobat reader).
If you take a chip with a 10-bit ADC and set it for 16-bit
mode, CCS will left-justify the result. You don't like that,
so you need to set the compiler for 10-bit mode, which will
right-justify the result.
Remove this line:
#device adc=16
Use this line instead:
#device adc=10
Original Post ID: 144515491
No_Fear
PostPosted: Tue Jun 24, 2003 1:45 am     Reply with quote
Hmm, I can understand now.Thank you very much for your help
No_Fear
:=:=Hi,
:=:=I wrote a code and it worked well(related with adc).Now i upgraded my code for 16 bit adc and it behaves weird.
:=It's behaving pretty much according to the chart in the
:=CCS manual, in the read_adc() section. (Page 130 of the
:=manual, or page 142 in the Acrobat reader).
:=If you take a chip with a 10-bit ADC and set it for 16-bit
:=mode, CCS will left-justify the result. You don't like that,
:=so you need to set the compiler for 10-bit mode, which will
:=right-justify the result.
:=Remove this line:
:=#device adc=16
:=Use this line instead:
:=#device adc=10
Original Post ID: 144515507
