Barcode Decoder Source Code
Post new topic   Reply to topic    CCS Forum Index -> Code Library
chingB
PostPosted: Sat Jul 09, 2005 12:56 am     Reply with quote
I am sharing my barcode decoder source code. I guess this would be helpful in the community.
I use a Barcode OEM Slot Type Module from FameTech or Tysso at http://www.barcode-manufacturer.com/ or at http://www.fametech.com.tw/. The exact part number is SR-070 and I use the infra-red models. You can also use 1022WM from Cipher Lab at http://www.cipherlab.com/en/.
The decoder source code:
#define ZERO_VAL                    0
#define ONE_VAL                     1
#define TWO_VAL                     2
#define THREE_VAL                   3
#define FOUR_VAL                    4
#define EIGHT_VAL                   8
#define ROW_INDEX                   4
#define COL_INDEX                   10
#define MODULO_43                   43  // barcode check digit calculation
#define REVERSE_SWIPE               110 // the badge id is swipe reverse
#define FORWARD_SWIPE               111 // the badge id is swipe forward
#define BARCODE_DATA_COUNT          8   // to char data per badge id
#define BARS_PER_CODE               5   // number of bars per char
// number of spaces per char
#define SPACES_PER_CODE             ((BARS_PER_CODE) - (ONE_VAL))
// half the barcode data count
#define HALF_BARCODE_DATA_COUNT     ((BARCODE_DATA_COUNT) / (TWO_VAL))
// maximum number of bars per badge id
#define MAX_BAR_COUNT               ((BARCODE_DATA_COUNT) * (BARS_PER_CODE))
// maximum number of spaces per badge id
#define MAX_SPACE_COUNT             ((MAX_BAR_COUNT) - (ONE_VAL))
// T3CON Register //
#define T3CON_BASE                  0xFB1
#define T3CON                       ((unsigned int *)T3CON_BASE)
boolean CaptureMode = FALSE;        // FALSE-Falling, TRUE-Rising capture
boolean BarStart = FALSE;           // TRUE-barcode capture started
boolean BarEnd = FALSE;             // TRUE-barcode capture ended
boolean SkipSpaceDone = FALSE;      // TRUE-skip first space barcode capture
int BarCnt = ZERO_VAL;              // bars counter
int SpaceCnt = ZERO_VAL;            // space counter
int16 BarTable[MAX_BAR_COUNT];      // bars 16-bit time capture value
int16 SpaceTable[MAX_BAR_COUNT];    // spaces 16-bit time capture value
byte BarcodeTable[BARCODE_DATA_COUNT];      // decoded barcode data
byte RawBarTable[BARCODE_DATA_COUNT];       // raw bar data table
byte RawSpaceTable[BARCODE_DATA_COUNT];     // raw space data table
byte BarPatternTable[COL_INDEX] = {
    17, 9, 24, 5, 20, 12, 3, 18, 10, 6
byte RevBarPatternTable[COL_INDEX] = {
    17, 18, 3, 20, 5, 6, 24, 9, 10, 12
byte Code3of9Table[ROW_INDEX][COL_INDEX] = {
    {'K','L','M','N','O','P','Q','R','S','T'},
    {'A','B','C','D','E','F','G','H','I','J'},
    {'1','2','3','4','5','6','7','8','9','0'},
    {'U','V','W','X','Y','Z','-','.',' ','*'}
// bars and space average time variables
typedef struct BarSpaceAveStruct
    int16 BarsAverageTime;
    int16 SpacesAverageTime;
} BAR_SPACE_AVE_STRUCT;
boolean ClockTick = FALSE;
int TickCnt = ZERO_VAL;
#int_timer0
void timer0_isr(void)
    TickCnt++;
    if (    TickCnt > THREE_VAL
         && ClockTick == FALSE)
        ClockTick = TRUE;
        // output toggle PIN_A0 (LED Blinker)
        #asm
        BCF 0xF92.0
        BTG 0xF89.0
        #endasm
    clear_interrupt(int_timer0);
#int_timer1
void timer1_isr()
    // timer overflow for no barcode data to capture
    disable_interrupts(int_timer1);
    if (BarStart == TRUE)
        BarStart = FALSE;       // reset bar capture to initial state
        SkipSpaceDone = FALSE;  // reset skip space to capture first space
        CaptureMode = FALSE;    // reset to falling edge capture
        BarEnd = TRUE;          // barcode capture has ended
        BarCnt = ZERO_VAL;      // reset bars counter
        SpaceCnt = ZERO_VAL;    // reset spaces counter
    clear_interrupt(int_timer1);
#int_ccp1
void ccp1_isr()
    if (    BarCnt >= MAX_BAR_COUNT
         && SpaceCnt > MAX_SPACE_COUNT)
        // disable CCP1 if bars and spaces count exceeds maximum count
        disable_interrupts(int_ccp1);
    if (CaptureMode == FALSE) // falling edge capture (bars)
        CaptureMode = TRUE;
            BarTable[BarCnt++] = CCP_1;
            BarStart = TRUE;
            enable_interrupts(int_timer1);
    else // rising edge capture (spaces)
        if (SkipSpaceDone == TRUE)
            SpaceTable[SpaceCnt++] = CCP_1;
            SkipSpaceDone = TRUE;
    // toggle capture CCP1CON mode select bit
    #asm
    MOVLW 0x01
    XORWF 0xFBD, F
    #endasm
    // reset timer1
    set_timer1(ZERO_VAL);
    clear_interrupt(int_ccp1);
void init_mcu(void)
   delay_ms(1000);          // delay for 1 seconds (stabilized MCU?)
   output_float(PIN_C2);    // set to input for CCP1 capture
   setup_adc_ports(NO_ANALOGS);     // setup PortA to digital I/O
   setup_ccp1(CCP_CAPTURE_FE);      // set CCP1 to falling edge capture
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);    // 20M/(4*8*65536)
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_16);  // 20M/(4*16*65536)
   set_timer0(ZERO_VAL);
   enable_interrupts(INT_CCP1);     // enable CCP1 interrupt on falling edge
   enable_interrupts(int_timer0);
   enable_interrupts(global);       // enable global interrupt
   output_low(PIN_A0);
   return;
void clear_barcode_buffers(void)
    int Idx;
    for (Idx = ZERO_VAL;
         Idx < MAX_BAR_COUNT;
         Idx++)
        BarTable[Idx] = ZERO_VAL;
        SpaceTable[Idx] = ZERO_VAL;
         Idx < BARCODE_DATA_COUNT;
         Idx++)
        BarcodeTable[Idx] = ZERO_VAL;
        RawBarTable[Idx] = ZERO_VAL;
        RawSpaceTable[Idx] = ZERO_VAL;
    return;
void display_code(void)
    int Idx;
    printf("\n\rBarcode = ");
         Idx++)
        printf("%c",BarcodeTable[Idx]);
    return;
BAR_SPACE_AVE_STRUCT get_average_time(int BarIdx, int SpaceIdx)
    int Idx;
    BAR_SPACE_AVE_STRUCT Midean;
    *(unsigned int32 *)&Midean = ZERO_VAL;
    for(Idx = ZERO_VAL;
        Idx < BARS_PER_CODE;
        Idx++)
        Midean.BarsAverageTime += BarTable[BarIdx + Idx];
        if (Idx < SPACES_PER_CODE)
            Midean.SpacesAverageTime += SpaceTable[SpaceIdx + Idx];
    Midean.BarsAverageTime /= BARS_PER_CODE;
    Midean.SpacesAverageTime /= SPACES_PER_CODE;
    return Midean;
void get_raw_code(void)
    int  BarIdx, SpaceIdx;
    int  Idx, TableIdx;
    byte BarPattern, SpacePattern;
    BarIdx = ZERO_VAL;
    SpaceIdx = ZERO_VAL;
    for (TableIdx = ZERO_VAL;
         TableIdx < BARCODE_DATA_COUNT;
         TableIdx++)
        BarPattern = ZERO_VAL;
        SpacePattern = ZERO_VAL;
        Midean = get_average_time(BarIdx, SpaceIdx);
             Idx++)
            BarPattern <<= ONE_VAL;
            if (BarTable[BarIdx] > Midean.BarsAverageTime)
                BarPattern |= ONE_VAL;
            if (    SpaceIdx < MAX_SPACE_COUNT
                 && Idx < SPACES_PER_CODE)
                SpacePattern <<= ONE_VAL;
                if (SpaceTable[SpaceIdx] > Midean.SpacesAverageTime)
                    SpacePattern |= ONE_VAL;
            BarIdx++;
            SpaceIdx++;
        RawBarTable[TableIdx] = BarPattern;
        RawSpaceTable[TableIdx] = SpacePattern;
    return;
byte reverse_special_char_space(int Spaces)
    if (Spaces == 14)
        return 7;
    else if (Spaces == 13)
        return 11;
    else if (Spaces == 11)
        return 13;
    else if (Spaces == 7)
        return 14;
        return Spaces;
byte get_code_3of9(byte BarPattern, byte SpacePattern, boolean Mode)
    byte Result='@';
    int ColIdx, RowIdx;
    if (BarPattern == ZERO_VAL)
        if (Mode == FORWARD_SWIPE)
            SpacePattern = reverse_special_char_space(SpacePattern);
        if (SpacePattern == 14)
            return '$';
        else if (SpacePattern == 13)
            return '/';
        else if (SpacePattern == 11)
            return '+';
        else if (SpacePattern == 7)
            return '%';
            return Result;
        for (RowIdx = ZERO_VAL;
             RowIdx < ROW_INDEX;
             RowIdx++)
            if (SpacePattern == (ONE_VAL << RowIdx))
                for (ColIdx = ZERO_VAL;
                     ColIdx < COL_INDEX;
                     ColIdx++)
                    if (    Mode == REVERSE_SWIPE
                         && BarPatternTable[ColIdx] == BarPattern)
                        return Code3of9Table[RowIdx][ColIdx];
                    else if (    Mode == FORWARD_SWIPE
                              && RevBarPatternTable[ColIdx] == BarPattern)
                        return Code3of9Table[THREE_VAL - RowIdx][ColIdx];
                        #asm nop #endasm
        return Result;
byte get_ref_code3of9(byte ch)
    if ( ch >= '0' && ch <= '9')
        return (ch - 48);
    else if (ch >= 'A' && ch <= 'Z')
        return (ch - 55);
    else if (ch == '-')
        return 36;
    else if (ch == '.')
        return 37;
    else if (ch == ' ')
        return 38;
    else if (ch == '$')
        return 39;
    else if (ch == '/')
        return 40;
    else if (ch == '+')
        return 41;
    else if (ch == '%')
        return 42;
   else return 100;
boolean get_check_digit(void)
    byte Idx, BarData;
    byte CheckDigit=0;
    for (Idx = ONE_VAL;
         Idx < BARCODE_DATA_COUNT - TWO_VAL;
         Idx++)
        BarData = BarcodeTable[Idx];
        CheckDigit += get_ref_code3of9(BarData);
    BarData = BarcodeTable[BARCODE_DATA_COUNT - TWO_VAL];
    if ((CheckDigit % MODULO_43) == get_ref_code3of9(BarData))
        return TRUE;
    return FALSE;
void reverse_barcode_table(byte *Table)
    byte Idx1, Idx2;
    byte ch;
    Idx2 = BARCODE_DATA_COUNT - ONE_VAL;
    for (Idx1 = ZERO_VAL;
         Idx1 < HALF_BARCODE_DATA_COUNT;
         Idx1++, Idx2--)
        ch = Table[Idx1];
        Table[Idx1] = Table[Idx2];
        Table[Idx2] = ch;
    return;
void interpret_code(void)
    int Idx;
         Idx++)
        BarcodeTable[Idx] = get_code_3of9(RawBarTable[Idx],
                                          RawSpaceTable[Idx],
                                          REVERSE_SWIPE);
    if (get_check_digit() == FALSE)
             Idx++)
                                              RawSpaceTable[Idx],
                                              FORWARD_SWIPE);
        reverse_barcode_table(BarcodeTable);
            // error reading badge id
            printf("\n\rBarcode Read Error!");
            clear_barcode_buffers();
            display_code();         // display badge id
    clear_interrupt(int_ccp1);      // clear CCP1 interrupt flag
    enable_interrupts(int_ccp1);    // re-enable CCP1 interrupt
    return;
The main loop:
    int T3ConVal;
    init_mcu();                 // initialize mcu
    clear_barcode_buffers();    // clear all buffers
    T3ConVal = *T3CON;          // read T3CON register
    T3ConVal &= 0x9F;           // timer1 is clock source for CCP1 module
    *T3CON = T3ConVal;          // update T3CON register
    while (TRUE)
       if (ClockTick == TRUE)
          TickCnt = 0;
          ClockTick = 0;
       if (BarEnd == TRUE)
          BarEnd = FALSE;
          get_raw_code();       // get raw code of captured data
          interpret_code();     // interpret captured data
The Serial Output:
\0A
Barcode = *RB1231*\0A
Barcode Read Error!\0A0D
Barcode Read Error!\0A\0D
Barcode = *RB1231*\0A \0D
Barcode = *RB1231*\0A\0D
Barcode = *MB2710*\0A\0D
Barcode = *MB2710*\0A \0D
Barcode = *RB1231*   \0D
Hope this would help.
Thank you.
grinch
barcode reader to pic16f877a
PostPosted: Mon Feb 06, 2006 5:32 am     Reply with quote
hi chingB!
i have project...theres a barcode reader(ps/2) and its connected to a pic16f877 any idea about that...?
grinch
PostPosted: Mon Feb 06, 2006 6:02 am     Reply with quote
hi!
do you a schematic diagram of what kind of ic's u r are using?
can i see it..
FGiordani
Re: Barcode Decoder Source Code
PostPosted: Thu Feb 16, 2006 10:12 am     Reply with quote
I'm Brazilian.I need of your hardware schematic of barcode circuit.
This code work for PIC16F877? Which Microchip use?
PostPosted: Thu Feb 16, 2006 12:36 pm     Reply with quote
ChingB has not posted on the forum for 6 months. He has probably
left the forum.
chingB
PostPosted: Fri Mar 31, 2006 12:23 am     Reply with quote
left the forum.
Sorry Guys I've been busy lately with my company projects.
I am now working with BitMicro (http://www.bitmicro.com) as a firmware engineer.
As of the moment I don't have a spare time but I will try my best to be part of the community esp. I luv doing firmware programming using PIC.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
