Eugeneo
16F877 to 18F452 /18F4520 |
Posted: Thu Feb 02, 2006 2:00 am |
Just a quick question for anybody who has been in this situation. I've have a project that needs to be ported from an 877 to a 452 or 4520 since 877 are going out of style. My first question is, should my code theoretically port over with no mods as long as I don't use any direct memory addressing. And is there a significant difference between the 452 and 4520.
I will look at the datasheets in detail later, but I was just trying to get a heads up on this topic.
Thanks |
aopg64
Joined: 17 Oct 2005 Posts: 28 Location: Hampshire, UK
Posted: Thu Feb 02, 2006 3:57 am |
Hi, I'm doing something similar from 16F876A to 18F2520. Unfortunately it's not a straight port over so far:
1) EEPROM locations different
2) SFR registers different
3) WDT not dynamically changeable any more
4) Device file constant names changed, e.g ADC ones, and if you don't pick the right one you end up chasing your tail for a day wondering why things don't work any more.
Those have been my problems so far. No doubt there'll be more!
Nige _________________ No comment! (Can't think of anything interesting to say!) |
Humberto
Posted: Thu Feb 02, 2006 10:03 am |
One of the best features of PIC + CCS is portability and flexibility.
I made a debugging board to adapt the 16F8xx & 18F4x2 to the ICD.
Changing only one jumper AND selecting the processor family
it is possible to start running with any of them.
I use this common header:
#case
//#define PIC16 Change ICD Jumper !!!
#define PIC18 // Change ICD Jumper !!!
#ifdef PIC16
#include <16F877.H>
#device ICD=TRUE
#fuses NOWDT,XT, NOPROTECT, BROWNOUT, PUT, DEBUG, NOLVP
#else
#include <18F452.H>
#device ICD=TRUE
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, \
NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB,
\NOEBTR, NOEBTRB
#endif
#define Xtal 4000000
#use delay(clock=Xtal)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,enable=PIN_C5,bits=8,errors)
If you are using ICD, be aware that 18F use different pinīs than 16F.
Microchip claims that the 18F452 is pin compatible with the 16F877, wich is different to say that
it has the same internal architecture. Anyway I don't know any other microcontroller where you
gain a x4 upgrade factor with minimum changes like this.
Humberto |
Eugeneo
Posted: Thu Feb 02, 2006 11:33 pm |
Good stuff. I've now have a working 4520. Now I've got to test it to death.
Thanks for the great heads up guys. |
