NJU6355
EmbdFreak
NJU6355
PostPosted: Sat Jan 28, 2006 4:07 am     Reply with quote
The example program for the NJU6355 prints ??:??:?? after setting the date and time. Ive altered the driver to suit my own pins and ve connected the 32khz xtal to drive it. Theres nothing much to see in the program, yet im pasting it here:
/* driver altered to make
#define RTC_DATA  PIN_A2
#define RTC_CLK   PIN_A3
#define RTC_CE    PIN_A4
#define RTC_IO    PIN_A5
#include <16F877a.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=4800, xmit=PIN_C4, rcv=PIN_C5)  // Jumpers: 8 to 11, 7 to 12
#include <nju6355.c>
BYTE get_bcd() {
  char first,second;
  do {
    first=getc();
  } while ((first<'0') || (first>'9'));
  putc(first);
  first-='0';
  do {
    second=getc();
  } while (((second<'0') || (second>'9')) && (second!='\r'));
  putc(second);
  if(second=='\r')
    return(first);
    return((first<<4)|(second-'0'));
void set_clock(){
   BYTE day, mth, year, dow, hour, min;
   printf("\r\nPress ENTER after 1 digit answers.");
   printf("\r\nYear 19: ");
   year=get_bcd();
   printf("\r\nMonth: ");
   mth=get_bcd();
   printf("\r\nDay: ");
   day=get_bcd();
   printf("\r\nWeekday 1-7: ");
   dow=get_bcd();
   printf("\r\nHour: ");
   hour=get_bcd();
   printf("\r\nMin: ");
   min=get_bcd();
   rtc_set_datetime(day,mth,year,dow,hour,min);
   printf("\r\n\n");
void display_bcd( BYTE n ) {
   putc( (n/16)+'0' );
   putc( (n%16)+'0' );
void display_3_bcd( char separator, BYTE a, BYTE b, BYTE c ) {
   display_bcd(a);
   putc(separator);
   display_bcd(b);
   putc(separator);
   display_bcd(c);
void main() {
   char cmd;
   BYTE day, mth, year, dow, hour, min, sec;
   rtc_init();
   printf("\r\nPress S to change, D to display: ");
   do {
      cmd=getc()&0xdf;
   } while ((cmd!='D')&&(cmd!='S'));
   if(cmd=='S')
     set_clock();
   printf("\r\n");
   while (TRUE) {
      rtc_get_date( day, mth, year, dow);
      display_3_bcd( '/', day, mth, year );
      printf("    ");
      rtc_get_time( hour, min, sec );
      display_3_bcd( ':', hour, min, sec );
      printf("\r");
      delay_ms(250);
Plz suggest a possible solution.
VanHauser
PostPosted: Sat Jan 28, 2006 5:28 am     Reply with quote
I have tested the program you posted with CCS 3.242 and it didn't even compile. You renamed get_number() function from EX_RTC.C example to get_bcd(), which is already defined in NJU6355.C. Rename your function back and update your code with the change. Maybe your compiler is too old and doesn't issue an error.
EmbdFreak
PostPosted: Sat Jan 28, 2006 6:15 am     Reply with quote
thanx for the reply. My compiler version is 3.203 which is surely a little older. Ive run the same example as is, without renaming that function as such. The newer version might have it renamed.
Plz suggest solution if possible
VanHauser
PostPosted: Sat Jan 28, 2006 7:04 pm     Reply with quote
I've already told you a possible solution. You have two functions with the same name. There's only one thing to do.
EmbdFreak
PostPosted: Tue Jan 31, 2006 12:18 am     Reply with quote
Actually the problem is slightly different. i tested the setup on breadboard and it gave the correct date,time(used A0-A3). I changed the ports in the driver to A2-A5 and designed a PCB assuming it would work again, but it prints ??:??:?? or 00:00:00. this is besides the fact that im not using the analog port anywhere else. This is why i didnt consider ur input for function renaming !
newguy
PostPosted: Tue Jan 31, 2006 12:20 am     Reply with quote
I'm pretty sure that pin A4 is open drain - it can't drive signals high without an external pullup.
Check the 877's data sheet to be certain, but I'm pretty sure about A4 being open drain. I know it is on the 18F252 and 452, and the 452 is pin compatible (pretty much) with the 877.
EmbdFreak
PostPosted: Tue Jan 31, 2006 12:42 am     Reply with quote
Thats correct, it infact is an open drain and thanx a lot for the input. Ill alter the code or pcb and will try again !
EmbdFreak
PostPosted: Tue Jan 31, 2006 12:57 am     Reply with quote
Thanks again, its working now. I have simply changed the port !
