Getting rubbish data on my hyper terminal....
sonicdeejay
PostPosted: Fri Jan 20, 2006 6:54 am     Reply with quote
I am connection to PIC and hyper terminal accordin to the pic below...
In hyper terminal, I use 9600-8-N-1 Xon/Off
I am getting rubbish data....when I use oscilloscope probe to the output, I can see that there are data stream output...
seems lik my baud setting aint right??
what settting should i use??
thx
sonic
Smile
Roebi
baud rate setting
PostPosted: Fri Jan 20, 2006 8:06 am     Reply with quote
Do you have a statement such as:
somewhere in your code? The clock=number should be the frequency of your oscillator circuit.
If this does not help yet, check the data sheet: The clock you are using may possibly not allow to set the baud rate generator such that it matches 9600 bps. The match should be better than 1 to 2 % - otherwize garbage will possibly result. If you can not set BRG such to meet this "band", change the oscillator frequency accordingly.
Example:
Assume you select BRGH =1, then
baudrate = clock /(16 * (BRG+1)) and setting BRG = 129 Arrow
baudrate = 9615 or 9600 + 0.16% which is ok.
Humberto
PostPosted: Fri Jan 20, 2006 8:23 am     Reply with quote
Two comments:
1) Try with another communication program. This forum is plenty of complaints regarding Hiperterminal.
2) Change the option Xon/Xoff by none.
Xon/Xoff is a protocol for control the flux of data between a computer and other devices,
if you are not managing this, do not use it.
The selected setting used in the code header must be the same used in the PC side.
Same Speed
Same number of Data bits
Same number of Stop bits
Same Parity
Same Data flux control.
In the Help Manual you will find how to configure the PIC comm.
Humberto
SherpaDoug
PostPosted: Fri Jan 20, 2006 10:18 am     Reply with quote
What are you using for a clock, a crystal, a ceramic resonator, the PIC internal oscillator, RC? Could it be that your clock is a little off frequency? Can you try the PIC at 10080 or 9120 baud (9600 +/- 5%)? Some PCs can be a few % off too.
On your scope can you compare a "U" sent by the PC vs a "U" sent by the PIC?
sonicdeejay
PostPosted: Mon Jan 23, 2006 12:41 am     Reply with quote
I am using 16 Mhz with 2 pieces of 22p F cap....
apart from hyper terminal...is there any SW that I can use to communicate??
Sad
edhaslam
PostPosted: Mon Jan 23, 2006 6:48 am     Reply with quote
Sad
Try using TeraTerm (use Google to search for their website) - it's freeware.
Ed
SherpaDoug
PostPosted: Mon Jan 23, 2006 8:32 am     Reply with quote
I prefer a program called Terminal, available free at http://bray.velenje.cx/avr/terminal
edhaslam
PostPosted: Mon Jan 23, 2006 11:22 am     Reply with quote
Looks good Exclamation
sonicdeejay
PostPosted: Tue Jan 24, 2006 12:17 am     Reply with quote
h**p://hp.vector.co.jp/authors/VA002416/teraterm.html
teraterm doesn't have WInXp version?? Sad
asmallri
PostPosted: Tue Jan 24, 2006 12:29 am     Reply with quote
teraterm doesn't have WInXp version?? Sad[/quote]
I use Teraterm Pro ver 2.3 (1998) on XP and it works perfectly.
Post your fuses...
Regards, Andrew
sonicdeejay
PostPosted: Tue Jan 24, 2006 12:48 am     Reply with quote
Post your fuses...[/quote]
I using terminal and I use 1uF cap..it is working ,,,
but data is stuff with rubbish??ppl...
sonicdeejay
PostPosted: Tue Jan 24, 2006 2:32 am     Reply with quote
#if defined(__PCM__)
#include <18F2331.h>
#use delay(clock=16000000)
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8) // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#endif
void main() {
int i, value, min, max;
//printf("Sampling:");
//setup_port_a( ALL_ANALOG );
//setup_adc( ADC_CLOCK_INTERNAL );
//set_adc_channel( 0 );
do {
output_high(PIN_A4);
//delay_ms(1000);
//printf("Sampling:\n");
printf("The Voltage is ");
printf(" 1500 ");
output_low(PIN_A4);
} while (TRUE);
this is my code...
Humberto
PostPosted: Tue Jan 24, 2006 6:16 am     Reply with quote
Your code should run.
Let's check the hardware: going to the schematic you posted, did you measure the
voltage generated by the MAX232 at PIN2 to Gnd and PIN6 to Gnd ?
Could you tell us the voltages at PINs 11, 12, 13 and 14 (MAX232) when the circuit is in idle state ?
Humberto
sonicdeejay
PostPosted: Fri Jan 27, 2006 3:57 am     Reply with quote
It works so fine...when I connect this way.....thx all for helping me out...
Cool
[img]http://www.photoi.org/share/upload3/1/2/810601127/max232connection.bmp[/img]
