ye
| continued discussion about structure pointer problem |
Posted: Wed Jan 11, 2006 4:42 am |
Dear all,
I raised a question about a pointer problem in structure. I think I still have some confusions over there not resolved and would like to seek further help here.
The original post is:
http://www.ccsinfo.com/forum/viewtopic.php?t=25600&highlight=userrecord
My further question is:
I acknowledge that the structure pointers in the original post were not assigned proper addresses initially and they ended up pointing at successive word addresses which caused interferances.
However, in my code, I did exactly the same as the suggested solution which didn't work on me! The code is kinda like:
| Code: | struct node
int tag;
char UserID[9];
char Password[9];
int admin_index;
int TestNo;
struct node* UserRecord[10];
struct node User[10];
for(i=0;i<10;i++)
UserRecord[i] = &User[i];
I actually have another soltion which is:
| Code: | struct node
int tag;
char UserID[9];
char Password[9];
int admin_index;
int TestNo;
struct node *UserRecord[10];
UserRecord[0] = malloc( sizeof(struct node ) );
for(i=1;i<10;i++)
UserRecord[i] = malloc( sizeof(struct node ) );
UserRecord[i] = UserRecord[i-1] + sizeof(struct node) ;
I thought it should have worked because all the pointers were assigned a proper address with a proper length of separation in memory. However it didn't work again.
what on earth is going wrong over there? |
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
Posted: Wed Jan 11, 2006 7:49 am |
I expected the first method to work.
What exactly happens when it does not work?
Here is another (cleaner?) way.
| Code: | struct node
int tag;
char UserID[9];
char Password[9];
int admin_index;
int TestNo;
for(i=0;i<10;i++)
UserRecord[i] = malloc(sizeof(struct node));
_________________ Regards, Andrew
Posted: Wed Jan 11, 2006 8:06 am |
I think the reason the malloc version would fail, is this line:
This is destroying the value already put into the pointer by the line before, and is making the assumption, that the memory blocks will be consecutive, and in order......
I would have expected the original version to work. I use structure pointers like this fairly frequently, and have not seen any problems.
ye
Posted: Wed Jan 11, 2006 9:11 am |
Thanks for your replies.
The aftermath of using the first method in my code was exactly the same as that described in the first post, i.e., when assigning a different string to a user record, contents of other user records get interferred.
Telmah, so are you saying when I am using malloc, the allocated memory location is randomly given and I would spoil the code if I add an additional statement trying to fix the memory blocks in order like
'UserRecord[i] = UserRecord[i-1] + sizeof(struct node) ; ' ? |
treitmey
| pointer to a struct |
Posted: Wed Jan 11, 2006 10:41 am |
I went through something like this before. Mark helped me out
It is order of eval and type casting the pointer to a struct.
| Code: | #include <18F452.H>
#case
#use delay(clock=40000000)
#fuses h4,nowdt,noprotect,nolvp
#use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG,disable_ints) // stderr(same as debug)
#zero_ram
#define NUM_USER_REC 15
struct node
char tag;
char UserID[9];
char Password[9];
char admin_index;
}; // Note this is not a node in linked list
struct node UserRecord[NUM_USER_REC],*ptrUserRecord[NUM_USER_REC];
//=================prototypes=================//
print_user(struct node *ptrUserRecord);
//======================= MAIN ============================//
char j,i,k;
setup_adc_ports(NO_ANALOGS);
set_tris_a(0);set_tris_b(0);set_tris_c(0);
set_tris_d(0);set_tris_e(0);
fprintf(DEBUG,"STARTING.\n\r");
for(i=0;i<NUM_USER_REC;i++){
ptrUserRecord[i]=&UserRecord[i];//assign pointer to address of struct
for(i=0;i<NUM_USER_REC;i++){//assign tag the value of index * 3
UserRecord[i].tag=i*3;
for(i=0;i<NUM_USER_REC;i++){//assign admin_index a value
UserRecord[i].admin_index=i+5;
for(i=0;i<NUM_USER_REC;i++){//assign UserID a value
sprintf(UserRecord[i].UserID,"Tim%u",i);
for(i=0;i<NUM_USER_REC;i++){//assign Password a value
sprintf(UserRecord[i].Password,"pass%u",i*2);
//---------------print the users-----------------//
for(i=0;i<NUM_USER_REC;i++){//print the users
print_user((struct node*)ptrUserRecord[i]);
// fprintf(DEBUG,"Tag=%u, ",((struct node*)ptrUserRecord[0])->tag);
// fprintf(DEBUG,"UserID=%s, ",((struct node*)ptrUserRecord[0])->UserID);
// fprintf(DEBUG,"Tag=%u, ",((struct node*)ptrUserRecord[1])->tag);
// fprintf(DEBUG,"UserID=%s, ",((struct node*)ptrUserRecord[1])->UserID);
// fprintf(DEBUG,"Tag=%u, ",((struct node*)ptrUserRecord[2])->tag);
// fprintf(DEBUG,"UserID=%s, ",((struct node*)ptrUserRecord[2])->UserID);
fprintf(DEBUG,"DONE!\n\r");
//=================print_user()=============================//
print_user(struct node* ptr)
char x;
fprintf(DEBUG,"Tag=%u\n\r",(struct node*)ptr->tag);
fprintf(DEBUG,"UID=%s\n\r",(struct node*)ptr->UserID);
fprintf(DEBUG,"Pswd=%s\n\r",(struct node*)ptr->Password);
fprintf(DEBUG,"Adm_indx=%u\n\r\n\r",(struct node*)ptr->admin_index);
return;
//fprintf(DEBUG,"%X \n\r", ((struct pkt*)p_pkt[i])->data[1]);
ye
Posted: Wed Jan 11, 2006 10:55 am |
treitmey, thanks for the demo.
Maybe it's not a good question, but for function print_user, since parameter 'ptr' has been defined as 'struct node *' in function definition, then why do you add an additional type casting at it whenever you use it inside the function body?
Also, in the demo, all operations were done with UserRecord[i] and I can't see the meaning of using pointers here. Could you explain please ?
Cheers |
treitmey
Posted: Wed Jan 11, 2006 10:58 am |
Not sure if that is required, but i think it need to be in there one of the two places.
The pointers are just giving you options. Like in the commented out printf statments. The fuction uses a pointer to a struct so that it can know the definition of the data types in the struct node.
In main I could have simply passed an address of the struct... &userrecord[i]
to my print_user function.
I'm not sure if i'm answering your question. |
