Guest_X44 Guest
| malloc() |
Posted: Thu Feb 05, 2004 5:41 pm |
Using malloc() gives me an error: Undefined identifier __DYNAMIC_HEAD
#include <stdlibm.h> is included
When compiling it opens up the file memmgmt.c and this is where the identifier __DYNAMIC_HEAD is located.
Why is is that it doesn't give an error of Undefined identifier for NULL as well, which is also in memmgmt.c ?
NULL, I realize, must be defined in CCS C.
Looking at the <stdlibm.h> file, the __DYNAMIC_HEAD is not defined.
Any thoughts? |
Guest_X44 Guest
Posted: Thu Feb 05, 2004 5:48 pm |
NULL is actually defined in another called in <stddef.h>
But the __DYNAMIC_HEAD is not defined. I can't find it, anyway. |
Guest_X44 Guest
Posted: Thu Feb 05, 2004 10:41 pm |
| Am I missing something here? |
abs
Posted: Thu May 20, 2004 12:25 pm |
Do you have the USE DYNAMIC_MEMORY directive?
I believe you need this directive to instruct the compiler to create the __DYNAMIC_HEAD object.
I placed the following directive at the top of my program, after the device directives:
#pragma USE DYNAMIC_MEMORY |
Posted: Tue Jan 10, 2006 3:14 pm |
| abs wrote: | Do you have the USE DYNAMIC_MEMORY directive?
BLOODY HELL!!! Why isn't this in the help file??!!!! |
Posted: Tue Jan 10, 2006 3:24 pm |
The current version of EX_MALLOC.C has the following line in it,
near the start of the file:
| Code: | // Includes the functionality for malloc()
#include <STDLIBM.H> |
Then, in STDLIBM.H, it has these lines near the top:
| Code: | #ifndef _STDLIBM
#define _STDLIBM
#USE DYNAMIC_MEMORY |
