hadeelqasaimeh
| comunictino through rs232 and lcd proplem |
Posted: Thu Jan 05, 2006 1:22 pm |
hi all
i try to communication between two pic16f874 through rs-232 , iuse the interrput
(#int_rda)on the second pic,but ihave no good result on lcd which supposed
to print the recieved information from the first pic,its print some time nothig
and other time print some of string character and some times print correctly.
note: i use protuse to make run,the apply hardware ,....ineed to say that
my lcd is working correctly.
here is the code of first pic | Code: |
#include <16f874.h>
#include "lcd_kbd1.c"
#include <string.h>
#fuses XT,NOWDT
#use delay(clock=4000000) //one instruction=1us
LCD_Init ( );
LCD_PutCmd ( CLEAR_DISP );
LCD_SetPosition ( LINE_16_1);
printf(LCD_PutChar," hello");
delay_ms(10000);
printf(" AT");
}//main
and here is the code of the second | Code: |
#include <16f874.h>
#include <string.h>
#fuses XT,NOWDT
static char RX[30], string1[30], string0[30], ptr ;
static int1 jj;
static int8 i;
#int_rda
void serial_isr() {
RX[i++]=getch();
strcpy(string1,RX);
jj=1;
enable_interrupts(INT_RDA);
jj=0;
LCD_Init ( );
if(jj==1) {
printf(LCD_PutChar,string1);
jj=0;
}//IF
}//MAIN
thanks alot |
hadeelqasaimeh
Posted: Sat Jan 07, 2006 10:31 am |
thanx alot the proplem is solved.  |
hadeelqasaimeh
| strtok |
Posted: Sat Jan 07, 2006 10:36 am |
i need to print characters limited by two known char in a recieved string.
i use the same code above with some correction.
i tried to use strtok,but how to print on lcd????
please any help |
