Setting baud rate, stop bits and parity for a MODBUS lib
dmendesf
PostPosted: Sat Dec 31, 2005 1:00 am     Reply with quote
Hi, i´m porting a MODBUS library (master and slave implementation, very memory efficient, callback functions for the slave part, very well designed to follow the standards...) to the CCS compiler. The only part missing is a function to set baud rate, stop bits and parity (in execution time). So i´ve tried this:
signed int set_mod_uart(unsigned long int baud, par_type parity, int stopbits)
   disable_modbus();
   g_parity = parity;
   g_baud = baud;
   switch(parity)
      case O:
         if(stopbits == 1)
            #use rs232(baud=9600,parity=O,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS,stream=MODBUS)
         else return -1;
      case E:
         if(stopbits == 1)
            #use rs232(baud=9600,parity=E,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS,stream=MODBUS)
         else return -1;
      case N:
         if(stopbits == 1)
            #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS,stream=MODBUS)
         else if(stopbits == 2)
            TXSTA |= 0x41;
         else return -1;
   switch(baud)
#if CCLOCK < 9497000
      case 1200:
         set_uart_speed(1200);
#endif
      case 2400:
         set_uart_speed(2400);
      case 4800:
         set_uart_speed(4800);
      case 9600:
         set_uart_speed(9600);
      case 19200:
         set_uart_speed(19200);
      case 38400:
         set_uart_speed(38400);
      case 57600:
         set_uart_speed(57600);
      case 115200:
         set_uart_speed(115200);
      default:
         return -1;
   calc_t35(baud);
   return 0;
Ignore for now the calls to "calc_t35()" and "disable_modbus()". I just can´t make this function work. With parity it never works, without parity it sometimes works, sometimes don´t. It gaves really strange results. I´m using 3.236. Any ideas?
PostPosted: Tue Jan 03, 2006 1:29 pm     Reply with quote
I've never seen a function to chande stop bits and parity in realtime in CS, but it would be really great.
