nokia 3310 driver req.
hunter07
PostPosted: Thu Dec 29, 2005 8:15 am     Reply with quote
could you?
guest
PostPosted: Thu Dec 29, 2005 1:11 pm     Reply with quote
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk    PIN_D4
#define nok_sda    PIN_D3
#define nok_dc    PIN_D2
#define nok_cs    PIN_D1
#define nok_res    PIN_D0
char char_row,charsel,charpos,chardata;       // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]=            {0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
                  0x00,0x00,0x5f,0x00,0x00,   // 21 !
                  0x00,0x07,0x00,0x07,0x00,   // 22 "
                  0x14,0x7f,0x14,0x7f,0x14,   // 23 #
                  0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
                  0x23,0x13,0x08,0x64,0x62,   // 25 %
                  0x36,0x49,0x55,0x22,0x50,   // 26 &
                  0x00,0x05,0x03,0x00,0x00,   // 27 '
                  0x00,0x1c,0x22,0x41,0x00,   // 28 (
                  0x00,0x41,0x22,0x1c,0x00,   // 29 )
                  0x14,0x08,0x3e,0x08,0x14,   // 2a *
                  0x08,0x08,0x3e,0x08,0x08,   // 2b +
                  0x00,0x50,0x30,0x00,0x00,   // 2c ,
                  0x08,0x08,0x08,0x08,0x08,   // 2d -
                  0x00,0x60,0x60,0x00,0x00,   // 2e .
                  0x20,0x10,0x08,0x04,0x02,   // 2f /
                  0x3e,0x51,0x49,0x45,0x3e,   // 30 0
                  0x00,0x42,0x7f,0x40,0x00,   // 31 1
                  0x42,0x61,0x51,0x49,0x46,   // 32 2
                  0x21,0x41,0x45,0x4b,0x31,   // 33 3
                  0x18,0x14,0x12,0x7f,0x10,   // 34 4
                  0x27,0x45,0x45,0x45,0x39,   // 35 5
                  0x3c,0x4a,0x49,0x49,0x30,   // 36 6
                  0x01,0x71,0x09,0x05,0x03,   // 37 7
                  0x36,0x49,0x49,0x49,0x36,   // 38 8
                  0x06,0x49,0x49,0x29,0x1e,   // 39 9
                  0x00,0x36,0x36,0x00,0x00,   // 3a :
                  0x00,0x56,0x36,0x00,0x00,   // 3b ;
                  0x08,0x14,0x22,0x41,0x00,   // 3c <
                  0x14,0x14,0x14,0x14,0x14,   // 3d =
                  0x00,0x41,0x22,0x14,0x08,   // 3e >
                  0x02,0x01,0x51,0x09,0x06,   // 3f ?
                  0x32,0x49,0x79,0x41,0x3e,   // 40 @
                  0x7e,0x11,0x11,0x11,0x7e,   // 41 A
                  0x7f,0x49,0x49,0x49,0x36,   // 42 B
                  0x3e,0x41,0x41,0x41,0x22,   // 43 C
                  0x7f,0x41,0x41,0x22,0x1c,   // 44 D
                  0x7f,0x49,0x49,0x49,0x41,   // 45 E
                  0x7f,0x09,0x09,0x09,0x01,   // 46 F
                  0x3e,0x41,0x49,0x49,0x7a,   // 47 G
                  0x7f,0x08,0x08,0x08,0x7f,   // 48 H
                  0x00,0x41,0x7f,0x41,0x00,   // 49 I
                  0x20,0x40,0x41,0x3f,0x01,   // 4a J
                  0x7f,0x08,0x14,0x22,0x41,   // 4b K
                  0x7f,0x40,0x40,0x40,0x40,   // 4c L
                  0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
                  0x7f,0x04,0x08,0x10,0x7f,   // 4e N
                  0x3e,0x41,0x41,0x41,0x3e};   // 4f O
BYTE const TABLE6[240]=            {0x7f,0x09,0x09,0x09,0x06,   // 50 P
                  0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
                  0x7f,0x09,0x19,0x29,0x46,   // 52 R
                  0x46,0x49,0x49,0x49,0x31,   // 53 S
                  0x01,0x01,0x7f,0x01,0x01,   // 54 T
                  0x3f,0x40,0x40,0x40,0x3f,   // 55 U
                  0x1f,0x20,0x40,0x20,0x1f,   // 56 V
                  0x3f,0x40,0x38,0x40,0x3f,   // 57 W
                  0x63,0x14,0x08,0x14,0x63,   // 58 X
                  0x07,0x08,0x70,0x08,0x07,   // 59 Y
                  0x61,0x51,0x49,0x45,0x43,   // 5a Z
                  0x00,0x7f,0x41,0x41,0x00,   // 5b [
                  0x02,0x04,0x08,0x10,0x20,   // 5c
                  0x00,0x41,0x41,0x7f,0x00,   // 5d
                  0x04,0x02,0x01,0x02,0x04,   // 5e
                  0x40,0x40,0x40,0x40,0x40,   // 5f
                  0x00,0x01,0x02,0x04,0x00,   // 60
                  0x20,0x54,0x54,0x54,0x78,   // 61 a
                  0x7f,0x48,0x44,0x44,0x38,   // 62 b
                  0x38,0x44,0x44,0x44,0x20,   // 63 c
                  0x38,0x44,0x44,0x48,0x7f,   // 64 d
                  0x38,0x54,0x54,0x54,0x18,   // 65 e
                  0x08,0x7e,0x09,0x01,0x02,   // 66 f
                  0x0c,0x52,0x52,0x52,0x3e,   // 67 g
                  0x7f,0x08,0x04,0x04,0x78,   // 68 h
                  0x00,0x44,0x7d,0x40,0x00,   // 69 i
                  0x20,0x40,0x44,0x3d,0x00,   // 6a j
                  0x7f,0x10,0x28,0x44,0x00,   // 6b k
                  0x00,0x41,0x7f,0x40,0x00,   // 6c l
                  0x7c,0x04,0x18,0x04,0x78,   // 6d m
                  0x7c,0x08,0x04,0x04,0x78,   // 6e n
                  0x38,0x44,0x44,0x44,0x38,   // 6f o
                  0x7c,0x14,0x14,0x14,0x08,   // 70 p
                  0x08,0x14,0x14,0x18,0x7c,   // 71 q
                  0x7c,0x08,0x04,0x04,0x08,   // 72 r
                  0x48,0x54,0x54,0x54,0x20,   // 73 s
                  0x04,0x3f,0x44,0x40,0x20,   // 74 t
                  0x3c,0x40,0x40,0x20,0x7c,   // 75 u
                  0x1c,0x20,0x40,0x20,0x1c,   // 76 v
                  0x3c,0x40,0x30,0x40,0x3c,   // 77 w
                  0x44,0x28,0x10,0x28,0x44,   // 78 x
                  0x0c,0x50,0x50,0x50,0x3c,   // 79 y
                  0x44,0x64,0x54,0x4c,0x44,   // 7a z
                  0x00,0x08,0x36,0x41,0x00,   // 7b
                  0x00,0x00,0x7f,0x00,0x00,   // 7c
                  0x00,0x41,0x36,0x08,0x00,   // 7d
                  0x10,0x08,0x08,0x10,0x08,   // 7e
                  0x78,0x46,0x41,0x46,0x78};   // 7f
void    nokia_init(void);
void    nokia_write_command(char bytefornokia_command);
void    nokia_write_data(char bytefornokia_data);
void    nokia_write_dorc(char bytefornokia);
void    nokia_gotoxy(int8 xnokia, int8 ynokia);
void    nokia_erase_y(int8 ynokia);
void    nokia_erase_x(int8 xnokia);
void    nokia_printchar(int8 cvar);
void    nokia_clean_ddram(void);
void    table_to_nokialcd(void);
void    nokia_plot(int8 xnokia,int8 plot_value8);
void    nokia_write_data_inv(char bytefornokia_data_inv);
void    nokia_clear_screen(void);
void    nokia_clear_xy(int8 xnokia, int8 ynokia);
void    nokia_print_uparrow(void);
void    nokia_print_downarrow(void);
void    nokia_print_leftarrow(void);
void    nokia_print_rightarrow(void);
void    nokia_print_degree(void);
void    nokia_print_lowbatdegree(void);
output_high(nok_dc);            // bytes are stored in the display data ram, address counter, incremented automatically
output_high(nok_cs);            // chip disabled
output_low(nok_res);            // reset chip during 250ms
delay_ms(10);         // works with less.....
output_high(nok_res);
nokia_write_command(0x21);   // set extins extended instruction set
nokia_write_command(0xc2);   // Vop  v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v)   ********************************************************************************************************************
nokia_write_command(0x13);   // bias
nokia_write_command(0x20);   // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
nokia_write_command(0x09);   // all on
nokia_clean_ddram();      // reset DDRAM, otherwise the lcd is blurred with random pixels
nokia_write_command(0x08);   // mod control blank change (all off)
nokia_write_command(0x0c);   // mod control normal change
nokia_gotoxy(0,0);         // 84*6=504      clear LCD
for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
output_low(nok_dc);   // byte is a command it is read with the eight SCLK pulse
output_low(nok_cs);   // chip enabled
nokia_write_dorc(bytefornokia_command);
nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia)         // serial write data or command subroutine
char caa;
for (caa=8;caa>0;caa--) {
      output_low(nok_sclk);
      // delay_us(2);
      if ((bytefornokia&0x80)==0){output_low(nok_sda);}
      else {output_high(nok_sda);}
      output_high(nok_sclk);
      bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia)      // Nokia LCD 3310 Position cursor
      nokia_write_command(0x40|(ynokia&0x07));   // Y axe initialisation: 0100 0yyy
      nokia_write_command(0x80|(xnokia&0x7f));   // X axe initialisation: 1xxx xxxx
nokia_gotoxy(0,ynokia);
printf(nokia_printchar,"              ");
char column;
for (column=0;column!=6;column++){
      nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar)               // Write 1 character to LCD
charsel=cvar;
table_to_nokialcd();
void table_to_nokialcd(void)   // extract ascii from tables & write to LCD
if (charsel<0x20)return;
if (charsel>0x7f)return;
for (char_row=0;char_row<5;char_row++) {      // 5 bytes
if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];}            // use TABLE5
else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];}            // use TABLE6
   nokia_write_data(chardata);      // send data to nokia
   nokia_write_data(0x00);      //    1 byte (always blank)
char i;
plot_value32=0;
   // plot_value32|=1;         // unremark this if you want dotgraph instead of bargraph
for (i=0;i!=plot_value8;i++){
   plot_value32|=1;         // remark this if you want dotgraph instead of bargraph
   plot_value32<<=1;
plot_value32|=2;            // bottom line is always filled
plot_llsb=(plot_value32&0xff);
plot_ulsb=((plot_value32>>8)&0xff);
plot_lmsb=((plot_value32>>16)&0xff);
plot_umsb=((plot_value32>>24)&0xff);
nokia_gotoxy(xnokia,1);
nokia_write_data_inv(plot_umsb);
nokia_gotoxy(xnokia,2);
nokia_write_data_inv(plot_lmsb);
nokia_gotoxy(xnokia,3);
nokia_write_data_inv(plot_ulsb);
nokia_gotoxy(xnokia,4);
nokia_write_data_inv(plot_llsb);
char caa;
      delay_us(2);
      if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
      bytefornokia_data_inv=bytefornokia_data_inv>>1;
nokia_erase_y(0);
nokia_erase_y(1);
nokia_erase_y(2);
nokia_erase_y(3);
nokia_erase_y(4);
nokia_erase_y(5);
nokia_gotoxy(xnokia,ynokia);
nokia_printchar(" ");
nokia_write_data(0x04);
nokia_write_data(0x02);
nokia_write_data(0x7f);
nokia_write_data(0x10);
nokia_write_data(0x20);
nokia_write_data(0x08);
nokia_write_data(0x1c);
nokia_write_data(0x2a);
nokia_write_data(0xf8);
nokia_write_data(0x06);
nokia_write_data(0x09);
// nokia_printchar("  ");
nokia_write_data(0x0f);
dyeatman
PostPosted: Thu Dec 29, 2005 1:25 pm     Reply with quote
Whomever you are "guest" (Michel?) it would have been much better to post your Nokia code in the CCS Code Library and point the user to it rather than putting it here. This would make it easier for other users to find in the future.
This is a good case for eliminating guest logins and also having a moderator (or moderators) that can move things around...
