Dima49
				| general C question |
				 Posted: Mon Dec 26, 2005 1:40 pm     |
				hi all,
I've got a genearal C question here (bit of a noob question)
Here are 2 snippets of code where I am defining a structure and then creating an array of the said structure.
Numero Uno:
 	  | Code: | 	 		  typedef struct
//hold variables used for controlling each individual LED in this structure
   short fadeDirection;      //indicate if LED fading up or down
   int fadeSpeed;            //speed of LED fading
   int fadeSpeedCount;         //counter used for each individual LED in BREATH mode
   int pwmDuty;            //length of the duty (on time of an LED)
   int ledMask;            //bits of PORTA or B that needed to be masked out to turn on the
                        //particular LED
}LED_PARAMS;
//populate array used to control all LEDs with initial states of all of the vars
LED_PARAMS LEDcontrol[NUM_LEDS]=
   {UP, 200, 0, 0, 0b00000001},
   {UP, 19, 0, 0, 0b00000010},
Numero Dose:
 	  | Code: | 	 		  struct
                        //particular LED
}LED_PARAMS;
   {UP, 19, 0, 0, 0b00000010}, |
As soon as I take typedef out the compiler spits out the following error:
*** Error 48 "C:\cygwin\home\d\pic_dir\fade_code\fade_code.c" Line 52(12,22): Expecting a (
*** Error 43 "C:\cygwin\home\d\pic_dir\fade_code\fade_code.c" Line 52(22,23): Expecting a declaration
The line num reffers to the begining of array declaration.
From what I understand, not using typedef is a newer way of dealing with structure declaration, but most compilers deal with it well. Furthermore, I have seen snippets on the forum with just struct.
I am just trying to understand more about use of structures and what stupid thing did I do to deserve that errror
THnX in advance for any help
                            d |
