| About storing large amount of data into ROM |
Posted: Tue Dec 13, 2005 8:19 am |
hi all,
I think this thread is the continuing version of the one posted not long ago. I was given the ideas of implementation from some kind guys but now having some practical implementation problem.
My problem is, since I am drawing some graphics and building some menus on LCD using 18f8722, there are a huge amount of pre-defined arrays in the code. I used to define all these arrays as constant so as to save RAM but in the end I was running out of ROM.
People recommanded I store these arrays using #ROM separating each array using a separator '~'. At the beginning of the code, a scanning of that storage area is executed to obtain the idea where these arrays are stored in the ROM.
The code is basically like this:
| Code: | #include<18f8722.h>
#device *=16
#include<math.h>
#include<stdlib.h>
#include<crc.c>
#USE RS232( BAUD = 9600, XMIT = PIN_G1, RCV = PIN_G2, STREAM = COM_A )
#USE RS232( BAUD = 9600, XMIT = PIN_C6, RCV = PIN_C7, STREAM = COM_B )
#rom 0x18000 = {"abc",'~',"1234",'~'}
int32 startAddress = 0x18000;
int i;
int32 j;
int32 length[2];
init_devices();
for(i=0;i<2;i++)
for(j=0;*(j+startAddress) != '~'; j++)
length[i] = j;
startAddress += (j+1);
fprintf(COM_B,"\nlength 1 = %ld,length 2 = %ld\n",length[0],length[1]);
I am storing arrays "abc" and "1234" in program memory, address starting at 0x18000. However, it doesn't work like what I expected. The lengths returned are: 248 and 634 which are obviously wrong. Can people spot any thing weird here?
Also, I was recommanded using #ORG but have no idea how to put this directive in. |
ye
Posted: Tue Dec 13, 2005 8:21 am |
sorry I forgot to login....
any thought,plz? |
asmallri
Joined: 12 Aug 2004 Posts: 1664 Location: Perth, Australia
| Re: About storing large amount of data into ROM |
Posted: Tue Dec 13, 2005 8:52 am |
You are searching for a byte value so you need to tell the compiler to use byte orientated storage in the #rom directive with the int8 specifier. I also added a define so you do not need to statically define the address more than once.
#define Table 0x18000
#rom int8 Table = {"abc",'~',"1234",'~'}
int32 startAddress = Table;
_________________ Regards, Andrew
ye
Posted: Tue Dec 13, 2005 9:01 am |
Hi Andrew,
Thanks for the reminding.
It still didn't seem to work. the lengths returned changed but still wrong. The returned lengths are now:
length 1 = 248,length 2 = 1068 |
asmallri
Posted: Tue Dec 13, 2005 9:30 am |
byte z;
for(i=0;i<2;i++)
for (j =0, z=0; z != '~'; j++)
read_program_memory(startAddress + j, &z, 1);
length[i] = j;
Posted: Tue Dec 13, 2005 9:31 am |
You can't use pointers to ROM.
To access the ROM memory, use the 'read_program_memory' call, with the address.
ye
Posted: Tue Dec 13, 2005 10:27 am |
Thanks guys, it works now...
Telmah, you remember you said using #org to avoid memory ovelap. How did you actualy use #org in this case? |
Posted: Tue Dec 13, 2005 1:13 pm |
The current compilers, _should_ create a memory segment if you use #rom. However I have had problems in the past with the compiler putting code into an area defined using this, and feel it is safer to use #org as well.
If you declare for instance:
#org 0x18000,0x180ff
Then the next item, is put into this memory segment. You can use #rom to do this.
So:
#org Table, Table+200
#org default
Ensures the area is reserved.
ye
Posted: Wed Dec 14, 2005 4:40 am |
| Thanks guys~ |
