Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
reverse order of bits
Post new topic   Reply to topic    CCS Forum Index -> Code Library
treitmey
PostPosted: Thu Jun 23, 2005 8:42 am     Reply with quote
Search items swap_bits, bit order, MSB LSB, reverse order
The function swap_bits put 7->0, 6->1, 5->2...
00010011 becomes 11001000
Made some changes to shorten it up. Its now equivalent to Neutone. See below time trials
#include <16F877.h>
#device *=16
#use delay(clock=16000000)
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=19200,xmit=PIN_E0,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
#define VER_MAJOR 1
#define VER_MINOR 00
int8 swap_bits(char data);
//=== Main ===
  char test,x,y,result;
  fprintf(DEBUG,"Starting\n\r");
  fprintf(DEBUG,"Bit swap %u.%02u\n\r",VER_MAJOR,VER_MINOR);
    result=0;
    test++;
    fprintf(DEBUG,"t=0x%X ",test);
    fprintf(DEBUG,"r=0x%X\n\r",swap_bits(test));
//===== swap_bits =====//
 int8 swap_bits( int8 data )
  int8 result=0;
  if(bit_test(data,0)) bit_set(result,7);
  if(bit_test(data,1)) bit_set(result,6);
  if(bit_test(data,2)) bit_set(result,5);
  if(bit_test(data,3)) bit_set(result,4);
  if(bit_test(data,4)) bit_set(result,3);
  if(bit_test(data,5)) bit_set(result,2);
  if(bit_test(data,6)) bit_set(result,1);
  if(bit_test(data,7)) bit_set(result,0);
  return result;
chingB
PostPosted: Sat Jun 25, 2005 12:29 am     Reply with quote
treitmey... this is of great help... reversing the endianess of the bits.
thanks.
dbotkin
PostPosted: Mon Aug 15, 2005 9:41 am     Reply with quote
Here's what I do:
#asm
count = 7
fliploop:
    RRF orig_value,F
    RLF new_value,F
    DECFSZ count
    goto fliploop
#endasm
I actually set count elsewhere, since I need to reverse a variable number of bits. I think you can use this instead, if you don't like using #ASM:
for(x=0;x<8;x++) {
    shift_left(&new_value,1,shift_right(&orig_value,1,0))
My way uses a lot less code space, though, that's the only reason I can think of that I would resort to ASM code in the middle of a C program.
Dale
treitmey
PostPosted: Mon Oct 17, 2005 8:07 am     Reply with quote
another one. Shamelessly stolen from the main forum.
instead of 0->8 it goes 8->0
int8 reverse( int8 backwards )
  int8 result=0;
  int8 x;
  x = 8;
  do
    if (bit_test(backwards,7))
      bit_set(result,0);
     rotate_left( &backwards,1);
     rotate_right( &result, 1);
  } while (--x);
  return result;
comvdd
PostPosted: Thu Nov 24, 2005 3:27 pm     Reply with quote
why not use a ones compliment
like
BYTE this;
this =0xFF;
this = ~this;
this now = 00;
and shift/send the byte out either to your own predefined port
or to a port driver made using quickbuilder or another
i think you need to read math.h
dont forget to #include it
if you use an accumulator code that also reads the pin bits when you wish to much as inline then you can task this to bits
just call and convert
its faster.... just one convert
treitmey
PostPosted: Mon Nov 28, 2005 9:39 am     Reply with quote
We are reversing the ORDER of bits. not simple inverting.
TEST=0b11000000
needs to become
0b00000011
your wrong in thinking ~ will do this
TEST=~TEST
produces 0b00111111
PostPosted: Fri Feb 16, 2007 10:57 am     Reply with quote
Being curious to performance I tested the several routines from this and some other threads in a loop with 256 different values. I tested in PCWH v3.249, compiling for a PIC18F458 and meassured the timing using the simulator stopwatch.
Sorted by execution speed, fastest first:
                                              Average instruction
Version    Author                   ROM RAM   cycles per loop
reverse_4  John Purbrick            284   0    24
reverse_3  Anonymous, Neutone        38   1    32
reverse_1  dbotkin (assembly)        18   2    63
reverse_2  Humberto, ckielstra       26   2    81
reverse_1a dbotkin (C)               32   2   120
reverse_0  Treitmey                  98   3   497
Conclusion: The lookup table method is the fastest but also uses the most memory. Dbotkin's assembly version is the smallest program but comes 3rd for speed. Neutone's version is a good compromise between code size and speed and for me the winning routine.
Note: About 4 more cycles can be saved by making the functions #inline.
Update 15-apr-2008: Treitmey's beautified version of Neutone's routine as posted on top of this thread creates exactly the same code and speed results. I like this new variant as to me it looks easier to read, but this is a matter of taste.
And here is the code used for creating the test results:
#include <18F458.h>
#FUSES HS, PROTECT,NOWDT, NOBROWNOUT,NOLVP
// Author: treitmey
// Reference: http://www.ccsinfo.com/forum/viewtopic.php?p=76547
char reverse_0(char test)
  char result=0,x;
  for (x=0; x<8; x++)
    if (bit_test(test,7-x))
      bit_set(result,x);
      bit_clear(result,x);
  return(result);
// Author: dbotkin
int8 reverse_1( int8 orig_value )
  int8 count;
  int8 new_value;
  count=7;
#asm
fliploop:
    RRCF orig_value,F
    RLCF new_value,F
    DECFSZ count
    goto fliploop
#endasm
  return new_value;
// Author: dbotkin
int8 reverse_1a( int8 orig_value )
  int8 x;
  int8 new_value;
  for(x=0; x<8; x++)
    shift_left(&new_value,1, shift_right(&orig_value,1,0) );
  return new_value;
// Authors: Humberto, ckielstra
// Reference: http://www.ccsinfo.com/forum/viewtopic.php?t=23356
int8 reverse_2( int8 backwards )
  int8 result=0;
  int8 x;
  x = 8;
  do
      bit_set(result,0);
  } while (--x);
  return result;
// Authors: Anonymous, Neutone
int8 reverse_3( int8 backwards )
  // First, we define each bit in both the backwards and forwards
  // integers.
  #bit bkwd_0 = backwards.0
  #bit bkwd_1 = backwards.1
  #bit bkwd_2 = backwards.2
  #bit bkwd_3 = backwards.3
  #bit bkwd_4 = backwards.4
  #bit bkwd_5 = backwards.5
  #bit bkwd_6 = backwards.6
  #bit bkwd_7 = backwards.7
  int forwards;
  #bit fwd_0 = forwards.0
  #bit fwd_1 = forwards.1
  #bit fwd_2 = forwards.2
  #bit fwd_3 = forwards.3
  #bit fwd_4 = forwards.4
  #bit fwd_5 = forwards.5
  #bit fwd_6 = forwards.6
  #bit fwd_7 = forwards.7
  forwards=0;
  if (bkwd_7) fwd_0=1;
  if (bkwd_6) fwd_1=1;
  if (bkwd_5) fwd_2=1;
  if (bkwd_4) fwd_3=1;
  if (bkwd_3) fwd_4=1;
  if (bkwd_2) fwd_5=1;
  if (bkwd_1) fwd_6=1;
  if (bkwd_0) fwd_7=1;
  return forwards;
// Author: John Purbrick
// Reference: http://www.ccsinfo.com/forum/viewtopic.php?t=8375
int8 const reverse_4[256] =
  0x00, 0x80, 0x40, 0xC0, 0x20, 0xA0, 0x60, 0xE0,
  0x10, 0x90, 0x50, 0xD0, 0x30, 0xB0, 0x70, 0xF0,
  0x08, 0x88, 0x48, 0xC8, 0x28, 0xA8, 0x68, 0xE8,
  0x18, 0x98, 0x58, 0xD8, 0x38, 0xB8, 0x78, 0xF8,
  0x04, 0x84, 0x44, 0xC4, 0x24, 0xA4, 0x64, 0xE4,
  0x14, 0x94, 0x54, 0xD4, 0x34, 0xB4, 0x74, 0xF4,
  0x0C, 0x8C, 0x4C, 0xCC, 0x2C, 0xAC, 0x6C, 0xEC,
  0x1C, 0x9C, 0x5C, 0xDC, 0x3C, 0xBC, 0x7C, 0xFC,
  0x02, 0x82, 0x42, 0xC2, 0x22, 0xA2, 0x62, 0xE2,
  0x12, 0x92, 0x52, 0xD2, 0x32, 0xB2, 0x72, 0xF2,
  0x0A, 0x8A, 0x4A, 0xCA, 0x2A, 0xAA, 0x6A, 0xEA,
  0x1A, 0x9A, 0x5A, 0xDA, 0x3A, 0xBA, 0x7A, 0xFA,
  0x06, 0x86, 0x46, 0xC6, 0x26, 0xA6, 0x66, 0xE6,
  0x16, 0x96, 0x56, 0xD6, 0x36, 0xB6, 0x76, 0xF6,
  0x0E, 0x8E, 0x4E, 0xCE, 0x2E, 0xAE, 0x6E, 0xEE,
  0x1E, 0x9E, 0x5E, 0xDE, 0x3E, 0xBE, 0x7E, 0xFE,
  0x01, 0x81, 0x41, 0xC1, 0x21, 0xA1, 0x61, 0xE1,
  0x11, 0x91, 0x51, 0xD1, 0x31, 0xB1, 0x71, 0xF1,
  0x09, 0x89, 0x49, 0xC9, 0x29, 0xA9, 0x69, 0xE9,
  0x19, 0x99, 0x59, 0xD9, 0x39, 0xB9, 0x79, 0xF9,
  0x05, 0x85, 0x45, 0xC5, 0x25, 0xA5, 0x65, 0xE5,
  0x15, 0x95, 0x55, 0xD5, 0x35, 0xB5, 0x75, 0xF5,
  0x0D, 0x8D, 0x4D, 0xCD, 0x2D, 0xAD, 0x6D, 0xED,
  0x1D, 0x9D, 0x5D, 0xDD, 0x3D, 0xBD, 0x7D, 0xFD,
  0x03, 0x83, 0x43, 0xC3, 0x23, 0xA3, 0x63, 0xE3,
  0x13, 0x93, 0x53, 0xD3, 0x33, 0xB3, 0x73, 0xF3,
  0x0B, 0x8B, 0x4B, 0xCB, 0x2B, 0xAB, 0x6B, 0xEB,
  0x1B, 0x9B, 0x5B, 0xDB, 0x3B, 0xBB, 0x7B, 0xFB,
  0x07, 0x87, 0x47, 0xC7, 0x27, 0xA7, 0x67, 0xE7,
  0x17, 0x97, 0x57, 0xD7, 0x37, 0xB7, 0x77, 0xF7,
  0x0F, 0x8F, 0x4F, 0xCF, 0x2F, 0xAF, 0x6F, 0xEF,
  0x1F, 0x9F, 0x5F, 0xDF, 0x3F, 0xBF, 0x7F, 0xFF};
  int8 result;
  int8 i;
  i = 0;
  do
    result = reverse_0(i);
  }  while(i++<255);
  for(;;);
Arsenic
PostPosted: Wed Oct 05, 2016 12:34 am     Reply with quote
Well, there's been a few years... now I finally made it work (?). Here, take this code and change the x values for 8 and 16 bits.
void reverse()
   char x;
   int1 helpme[32];                         //Store the bits.
   for( x = 0; x < 32; x++)
      helpme[31-x] = bit_test(Data,x); //Data is any INT32 variable
   for (x = 0; x < 32; x++){
      if(helpme[x]==0){
         bit_clear(DataSh,x);   //DataSh will be the result.
      else{
         bit_set(DataSh,x);
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
