multi-Master how do i do it? aswser please
hqv
PostPosted: Thu Nov 17, 2005 9:13 pm     Reply with quote
Master-slave:
hello everybody:
my problem is this:
i have two pic's 16f877 and i need to transmit info between them,for this i supose to use the i2c protocol ,but i don't know whether it's possible.
i don't know as to do it?
everything information will be important .
thanks
hqv
dyeatman
PostPosted: Thu Nov 17, 2005 9:43 pm     Reply with quote
Did you try looking at the FAQ?
CCS provides the hookup diagram and code for a simple comunications setup...
http://www.ccsinfo.com/faq/?23
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Nov 17, 2005 10:04 pm     Reply with quote
I'm curious about the multi-master I2C too (and there have been discussions about it in the forum). The diagram you have given the link to is for RS485. Although multi-master I2C would look pretty much the same, except there will be no bus transceivers.
dyeatman
PostPosted: Thu Nov 17, 2005 10:22 pm     Reply with quote
Actually, if you look at it more closely RS485 is just one of the types of communications. It also shows a direct single wire buss hookup. You gave no indication of the type of speed you require. For low speed the single wire buss hookup can be used or two lines can be used for higher speed duplex comms by modifying the routines already provided. A third type would be a direct highspeed connection of the two hardware UARTS TX=>RX and vice versa. No bus transceivers are needed there either. Using the UARTS you dont need any "drivers" just standard RS232 serial printf/putc/getc routines. Although more "elegant" I think I2c is a little overkill and complicated for a simple chip to chip hookup like this.
