edhaslam
| PICs with two USARTs? |
Posted: Mon Nov 14, 2005 7:34 am |
Does anyone know if there are any smaller PICs other than the PIC18F6722 and the PIC18F8722 that have two hardware USARTs?
I'm going to be parsing data from a GPS module and a Honeywell HMR3300 (digital compass module) at 9600 baud, so I'm a little reluctant to use a bit banged method for either. Also, the PCB that I'm laying out is pretty small, so space and tracking is an issue as the aforementioned PICs only come in a TQFP package.
Any advice would be appreciated.
Ed |
Posted: Mon Nov 14, 2005 9:41 am |
The alternative solution, is to use something like the MAX3110, with a smaller PIC. Provided you have SPI, as well as a UART. The 'pity' is that you presumably don't need the RS232 transceivers, since this has the equivalent to a MAX232 'built in', and can buffer both the PIC's port,and it's own port, making it then an efficient use of space. Philips were doing a similar SPI-UART bridge, the SC16IS75x/76x. This is available in much smaller packages, but is relatively 'recent', so availablility may be more of an issue.
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
| Re: PICs with two USARTs? |
Posted: Mon Nov 14, 2005 9:52 am |
| edhaslam wrote: | Does anyone know if there are any smaller PICs other than the PIC18F6722 and the PIC18F8722 that have two hardware USARTs?
Ed |
An 18F PIC will have no problem bit banging a 9600 baud modem (assuming you have a fast enough clock). An 18F PIC at 40MHz is capable three serial ports (two bitbanged) at 115Kbps FDX. _________________ Regards, Andrew
edhaslam
Posted: Mon Nov 14, 2005 11:21 am |
| Ttelmah wrote: | The alternative solution, is to use something like the MAX3110, with a smaller PIC. Provided you have SPI, as well as a UART. The 'pity' is that you presumably don't need the RS232 transceivers, since this has the equivalent to a MAX232 'built in', and can buffer both the PIC's port,and it's own port, making it then an efficient use of space. Philips were doing a similar SPI-UART bridge, the SC16IS75x/76x. This is available in much smaller packages, but is relatively 'recent', so availablility may be more of an issue.
Yeah, all the signals that I will be parsing will be TTL level, so no need for an RS232 tranceiver. I'll check out the Phillips chip though, is it sounds as though it could be useful.
| asmallri wrote: |
An 18F PIC will have no problem bit banging a 9600 baud modem (assuming you have a fast enough clock). An 18F PIC at 40MHz is capable three serial ports (two bitbanged) at 115Kbps FDX. |
This might have to be the other way of doing it as i'm struggling with the board layout at the moment. Maybe I'll do some tests with a low-end 18Fxxxx device and see how reliable it will be. How do you achieve 40MHz? Is it done by having a 20MHz clock and using the internal PLL?
Many thanks,
Ed |
Posted: Mon Nov 14, 2005 11:25 am |
No, it's done by having a 10MHz clock and the internal PLL.
The PLL, is *4 on most PICs.
edhaslam
Posted: Tue Nov 15, 2005 2:12 am |
| Ttelmah wrote: | No, it's done by having a 10MHz clock and the internal PLL.
Thanks Ttelmah
Ed |
Posted: Tue Nov 15, 2005 5:18 am |
The MAX3100 is also an SPI to UART interface without RS232 buffers.
Check it out. |
