help with internal oscilator on PIC16F628
esorato
PostPosted: Thu Nov 10, 2005 6:01 am     Reply with quote
Hi guys
I´m new in this group and I´m having a trouble with internal oscilator.
I did the test program bellow:
//teste.c
#include "C:\temp\ODO\teste.h"
#define testepin PIN_A0 // Move asento para cima
port_b_pullups(TRUE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
while(true)
delay_ms (10); // delay antes de ler o dado
output_low(testepin);
output_high(testepin);
//teste.h
#include <16F628.h>
#fuses NOWDT,INTRC_IO, PUT, NOPROTECT, BROWNOUT, MCLR, LVP, NOCPD
I expected that testepin changes is state every 10ms but nothing happens.
I´m suspecting of internal oscilator programming but I´m not sure.
Someone could help me ?
thank´s
Edson
asmallri
PostPosted: Thu Nov 10, 2005 6:15 am     Reply with quote
Depending on your circuit, you may need to change LVP to NOLVP. You may also need to disable the analog input on A0 (I have not looked at the datasheet for this processor).
Regards, Andrew
esorato
PostPosted: Thu Nov 10, 2005 6:55 am     Reply with quote
Thank´s
I´m programming with PicStart Plus (stand alone not in circuit).
I´m using the configuration bits of MPLAB to program and I´m enabling Low voltage Program.
Regarding the configuration of A0: If I use the project wizard and configure the port to output I´m not disabling analog input ???
Edson
asmallri
PostPosted: Thu Nov 10, 2005 7:49 am     Reply with quote
This is probably your problem. Set the NOLVP fuse.
I noticed there was no SETUP_ADC_PORTS() function call in the code you have listed to select digital I/O however this should not be a problem as you are using the port as an output.
Regards, Andrew
esorato
PostPosted: Thu Nov 10, 2005 7:53 am     Reply with quote
OK.
Thank´s. I´ll try this.
esorato
PostPosted: Fri Nov 11, 2005 5:38 am     Reply with quote
It worked.
But it´s strange because when I use CC5x itsn´t necessary change to no low voltage program.
Anyway... it´s working.
Tank´s
Edson
