Bootloader for a 18f4520
Pota78
PostPosted: Thu Nov 10, 2005 3:12 am     Reply with quote
Hi everyone, I read many post about Bootloaders but I'm not able to find a simple bootloader for the 18f4520...
Every bootloader I found is for 18f452 and I'm not sure the code is portable to his 0 friend...
I tried the tinybootloader but I was not able to make it work...
Have you ever used a bootloader with this pic?
what did you use? Thank you very much
asmallri
Re: Bootloader for a 18f4520
PostPosted: Thu Nov 10, 2005 3:28 am     Reply with quote
The fuses are different. Yes I have used a bootloader with this PIC - it was my own.
Regards, Andrew
Pota78
PostPosted: Thu Nov 10, 2005 3:39 am     Reply with quote
From which code have you started from? If I ask you to send me your code I have not many possibilities that you send it to me, right? Smile
By the way, what program did you use to send the hex file to the pic? hyperterminal?
Thank you very much,
Andrea
asmallri
PostPosted: Thu Nov 10, 2005 3:56 am     Reply with quote
I wrote my own code in assembler however it is possible for you to modify the bootloader code provided by CCS for this PIC.
I use my own application to upload, download, erase target devices. I sell my bootloaders so sorry but no I cannot send it to you but I am sure someone can point you to a free bootloader if you do not want to modify the CCS bootloader yourself.
Regards, Andrew
Pota78
PostPosted: Thu Nov 10, 2005 4:11 am     Reply with quote
Thank you very much... so, is there anyone else who could suggest me a working (and free) Bootloader for pic18f4520?
Andrew, my name is Andrea, the italian translation of Andrew, we have the same name... sure that you cannot send me just a little portion of the code? Smile
Naturally i'm joking, thank you very much Smile
Andrea
Pota78
PostPosted: Thu Nov 10, 2005 4:13 am     Reply with quote
I'm still here...
In the CCS bootloader I find this comment after the #use rs232 directive:
//Jumpers: 8 to 11, 7 to 12
what does it mean?
PostPosted: Thu Nov 10, 2005 8:59 am     Reply with quote
andrea,
the following bootloader should either work directly or with only trivial modifications...
http://www.microchipc.com/PIC18bootload/
jds-pic
Pota78
PostPosted: Thu Nov 10, 2005 12:01 pm     Reply with quote
Thank you, but I found the error in my customization of the tiny bootloader and now it works great Smile
Thank you very much
Andrea
PostPosted: Thu Nov 10, 2005 5:39 pm     Reply with quote
What did you customize to get it to work? Question
Very Happy
Thank you very much
Andrea
Pota78
PostPosted: Fri Nov 11, 2005 8:54 am     Reply with quote
I have choosen the right pic after the LIST directive (18f4520)
I have written the right oscillator frequency (in my case 8000000)
I have deleted the __config directives and I have re-written them without using the CONFIGXX words (Config1h etc.)
Ex:
config ieso=off, OSC = HS,BOREN = ON Etc...
I set the baud rate to 57600 first (not very stable) and to 38400 then...
And that's all, I 've used mpasm to assemble...
To use tiny bootloader I use the reset pin (as described on tiny website).
It's working great now Smile
