		| Author | Message |
		| Atma
				| Programming a PIC |
				|  Posted: Wed Nov 09, 2005 5:33 am |   |
				| Hi there
 I am trying to program a PIC with another PIC. I managed to read the target ID of the device and i manged to erase the device. Now i am trying to program the device. I tried sending one byte(hard coded - defined as a) to write to the memory and then used a normal programmer (ICD2) to read back the target PIC and see if the byte was written in memory but it wasnt.when i checked with the oscilloscope, i could see the bits coming out(sent) on the data pin when the clock pin cycled 16 times but couldnt read it.  I have pasted my code below. Can anyone tell me what I am doing wrong?
  	  | Code: |  	  | int8 a = 0xCB;
 int  PIC_HEX_ProgMem_LastLoadedAddress;
 #define P_MCLR PIN_B0 //Pin MCLR
 #define P_DATA PIN_B2 //pin RB7
 #define P_CLOCK PIN_B1 //pin RB6
 #include <16F873.h>
 #fuses XT,NOWDT,BROWNOUT, PUT, NOLVP
 #use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
 typedef int16 WORD;
 typedef short BOOL;
 //typedef int16 FILE;
 #define PIC_CMD_LOADCONFIG 0x00
 #define PIC_CMD_LOADPROGRAM 0x02
 #define PIC_CMD_READPROGRAM 0x04
 #define PIC_CMD_BEGINERASEPROGRAM 0x08
 #define PIC_CMD_INCADDRESS 0x06
 #define PIC_CMD_LOADDATA 0x03
 #define PIC_CMD_BULKERASE1 0x01
 #define PIC_CMD_BULKERASE2 0x07
 #define PIC_CMD_ENDPROGRAM 0x0E
 #define PIC_CMD_BEGINPROGRAM 0x18
 #define PIC_HEX_ID_BUFFER_SIZE   4 /* max size of ID memory      */
 #define PIC_HEX_NR_CONFIG_WORDS  2
 #define PIC_HEX_PROG_BUF_SIZE 8192 /* max size of program memory */
 #define buffersize 64
 #define lConfMemBase 0x2000
 #define lConfWordAdr 0x2007
 #define wCfgmask_bandgap 0x0000
 #define wCfgmask2_used 0x0000
 #define code_protection_bits 0x3030
 #define data_protection_bits 0x0100
 char buffer[buffersize];
 WORD PIC_HEX_prog_buf[PIC_HEX_PROG_BUF_SIZE];
 WORD PIC_HEX_id_buffer[PIC_HEX_ID_BUFFER_SIZE];
 WORD PIC_HEX_config_word[PIC_HEX_NR_CONFIG_WORDS];
 void program_mode() //puts to program/verify mode
 output_low(P_DATA);
 output_low(P_CLOCK);
 output_low(P_MCLR);
 delay_us(1);
 output_high(P_MCLR);
 void send_command(unsigned char cmd) //sends a command
 int i;
 output_low(P_DATA);
 output_low(P_MCLR);
 delay_us(1);
 for(i = 0; i< 6; i++)
 if(bit_test(cmd, i))
 output_high(P_DATA);
 output_low(P_DATA);
 output_high(P_CLOCK);
 void sendData(unsigned int tempData) //loads 14 bit data when clock cycles 16 times
 char i;
 unsigned char b;
 for (i=0; i<16; i++)
 if( bit_test(tempData, i))
 output_low(P_DATA);
 unsigned int readData() //reads a 14bit data word when the clock cycles 16 times
 char i;
 int16 tempData = 0;
 for (i = 0; i<16; i++)
 if(input(P_DATA))
 tempData |= 0x8000;
 tempData |= 0x0000;
 tempData >>= 1;
 tempData >>= 1;
 tempData &= 0x3FFF;
 return tempData;
 void Program_Flash(WORD w) //programs a word
 sendData(w);
 send_command(PIC_CMD_BEGINPROGRAM);
 delay_ms(10);
 void LoadConfig (int base) //loads config
 int i,n;
 send_command(PIC_CMD_LOADCONFIG);
 sendData(PIC_HEX_config_word[0]);
 n = base - lConfMemBase;
 for(i=0;i<n;++i)
 send_command(PIC_CMD_INCADDRESS);
 BOOL Program(WORD *buf, int n, WORD mask, int loadcmd, int readcmd, int base) //program function
 int i;
 WORD r, w;
 WORD wFlags;
 BOOL still_ok = TRUE;
 program_mode();
 if ((base >= lConfMemBase) && (base <= lConfWordAdr))
 LoadConfig(base);
 for(i=0; i<n; ++i)
 w=buf[i] & mask;
 send_command(loadcmd);
 Program_Flash(a);
 output_low(P_MCLR);
 char value;
 int i;
 WORD w;
 int16 storage;
 // printf(" Welcome to the PIC programmer\n");
 // printf("software was compiled on");
 //  printf(__DATE__);
 // printf("\tat about\t");
 //printf(__TIME__);
 setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
 setup_timer_1(T1_DISABLED);
 enable_interrupts(INT_RDA);
 enable_interrupts(global);
 program(PIC_HEX_prog_buf, PIC_HEX_ProgMem_LastLoadedAddress+1,0x3FFF,PIC_CMD_LOADPROGRAM,PIC_CMD_READPROGRAM,1);
 thanks in advance
		| Ttelmah Guest
				|  Posted: Wed Nov 09, 2005 5:57 am |   |
				| Well, without even looking at the program itself, youcannot have these declarations (in fact I'm suprised the compiler does not moan...)
  	  | Code: |  	  | typedef int16 WORD;
 You need to rethink your storage in the local PIC. You should declare a buffer, that is _only_ the size of a 'page' on the target PIC, put a block of data into this, and transfer just this small block 'offset' by a variable that represents the starts of the block in the destination memory.
 As it stands, you are trying to define a buffer that is 16384 bytes long, on a PIC that only has 192 bytes of RAM...
		| PCM programmer
				|  Posted: Wed Nov 09, 2005 2:02 pm |   |
				|  	  | Quote: |  	  | #include <16F873.h>
 You're using the XT oscillator setting with a 20 MHz crystal.
 It's probably not going to start-up in a reliable way.
 You should change it to HS.
 Look in the 16F873 data sheet, in the following section, for
 a chart which shows the recommended oscillator settings,
 based on the crystal frequency:
 TABLE 12-2: CAPACITOR SELECTION FOR CRYSTAL OSCILLATOR
 | You cannot post new topics in this forum You cannot reply to topics in this forum
