Code Error
cuite23
Code Error
PostPosted: Sun Nov 06, 2005 8:41 am     Reply with quote
When I run the below code I get the error "Expect a, or )" on the first line. I thought everything was defined correctly. Any suggestions?
void delay_10us(byte t); // max of 255 * 10 us
void delay_ms(long t); // delays t millisecs - max of 65,535 ms
void lcd_char(byte c);
void lcd_data_nibble(byte c);
void lcd_cmd_byte(byte c);
void lcd_cmd_nibble(byte c);
void lcd_shift_out(byte x);
void lcd_init(void);
void lcd_clr(void);
void lcd_clr_line(byte line);
void lcd_cursor_pos(byte line, byte pos);
void lcd_str(char *s);
void lcd_dec_byte(byte val, byte digits);
void lcd_hex_byte(byte val);
char num_to_char(byte val);
dyeatman
PostPosted: Sun Nov 06, 2005 8:53 am     Reply with quote
Where's the rest of the code?
What version of CCS compiler are you using?
Please post the CCS version and all your code from the beginng to this point...
PostPosted: Sun Nov 06, 2005 11:07 am     Reply with quote
He's trying to compile Peter H. Anderson's code, here:
http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html
I was able to get his code to compile by getting rid of the #case
statement. Then it compiled with PCM vs. 3.235 with no errors.
//#case // Comment out this line.
#include <16f84.h>
#include <string.h>
#include <defs_f84.h>
dyeatman
PostPosted: Sun Nov 06, 2005 11:14 am     Reply with quote
Wow! How did you pick up on that?
I have his code here, used it quite a few times and still didn't make the connection. You must work with his code a lot.
Looking at it closely now I can pick up on some of the similarities but it wasn't obvious to me... I'm impressed Exclamation
PostPosted: Sun Nov 06, 2005 11:22 am     Reply with quote
I have a good memory and I spotted this line as being part of his code:
dyeatman
PostPosted: Sun Nov 06, 2005 11:25 am     Reply with quote
Yeah, that line was the one I finally recognized when I went back and looked at it earlier. That and the comment Peter put in the line following.
Unfortunately my memory just isn't what it used to be. It seems to happen to most of us folks over 50... Good catch!
cuite23
PostPosted: Tue Nov 08, 2005 3:15 pm     Reply with quote
thank you. I got rid of the #case
