2 rs232 diferent speeds?????
jccsantos
PostPosted: Tue Nov 01, 2005 10:05 am     Reply with quote
I want to know if this is valid???? and if is workīs rigth? (problemīs in different speedīs)
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,stream=pc)
#use rs232 (baud=127000,parity=O,xmit=PIN_D0,rcv=PIN_D1,stream=ext)
   byte c;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
  while (true) {
     c=fgetc(ext);
     fputc(c, pc);
Need help!!!!!!!!!!!!!
Edit only for a copy paste problem, bracket
asmallri
PostPosted: Tue Nov 01, 2005 10:08 am     Reply with quote
you're missing a bracket on the second use rs232 statement
Regards, Andrew
