Set all PIC output pins high or low in 1 instruction
Futterama
PostPosted: Tue Nov 01, 2005 5:15 am     Reply with quote
Hello forum,
I'm building a LCD display driver with a 40pin PIC.
For that, I need to be able to change state (high or low) on all the outputs at the exact same time. Even if I run the PIC at 8MHz internal OSC, the small delay on the output waveforms to the LCD segments will perhaps damage the LCD over time.
So, how can I set the output state on several pins at the same time? This involves 4 ports right now, RA, RC, RD and RE.
Some pins will go from high to low, while others will go from low to high, all should be done in 1 instruction.
I hope you can help me out Cool
Regards,
Futterama
neil
LCD driving
PostPosted: Tue Nov 01, 2005 5:40 am     Reply with quote
Don't forget some pics have a built in hardware LCD driver. There is the old 16C925 through to the 18F8490. Here is a chart of LCD driving pics.
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=107&mid=10&lang=en&pageId=74
Surely this would be easier than pin toggling in software. You will probably end up electroplating your LCD segments if your program pauses/hangs!
Hope this helps!
Futterama
PostPosted: Tue Nov 01, 2005 7:28 am     Reply with quote
Thanks for the hint, neil.
There is just two problems:
1. The PIC has to be either DIP or SOIC package. These are the only ones I can solder.
2. The PIC have to be supported by my programmer. And unfortunately neither of the LCD-PICs is supported at the moment.
I can see that the PIC16F913 would be a good choice. My LCD has 2 commons and 15/14 segments.
Perhaps I can do some tricks to make my programmer support the PIC16F913.
I'll look into it. Thanks.
Mark
PostPosted: Tue Nov 01, 2005 7:34 am     Reply with quote
The pic can't do it alone. You will need to use some sort of buffer where you can latch the signals at once.
asmallri
PostPosted: Tue Nov 01, 2005 7:36 am     Reply with quote
Instead of driving the LCD directly from the PIC, use four serial-to-parallel shift registers with the output enables commoned. This means you only need a small footprint PIC and can talk to the LCD via the SPI interface (or bit bang). From memory the 74hc595 is the right type of device.
Regards, Andrew
Futterama
PostPosted: Wed Nov 02, 2005 1:24 am     Reply with quote
I guess this is only true for non-LCD-compatible PIC devices?
My PIC programmer software has recently been updated to support the PIC16F913 which have LCD support. I'll try to use this one.
Otherwise, I can use XOR gates for the drive.
asmallri, I'm not sure how that thing works, and it seems to me that the PIC16F913 will do the job (1 PIC compared to 1 PIC + 4 74HC595's).
But thank you all for your suggestions, I'll try the PIC16F913 first Cool
Mark
PostPosted: Wed Nov 02, 2005 7:02 am     Reply with quote
Yes
asmallri
PostPosted: Wed Nov 02, 2005 7:46 am     Reply with quote
The beauty of the serial to parallel shift registers is that are located next to the pins to be driven and you only require two or three pins to go to the PIC. Makes it very easy to layout boards. Hard to believe I am saying this but.. sometimes a little external logic can greatly simplify a job.
Regards, Andrew
