Strange errors list ....
Flavio58
PostPosted: Tue Jun 03, 2003 2:39 am     Reply with quote
One week ago I bought the PCH compiler....
I use it in a MPLAB ICD 2 environment with PICDEEM 2 PLUS.....
When I try to use the compiler using MPLAB make option, ccs show me a long list
of errors as these :
*** Error 48 "SkyMilCtrl.c" Line 464(5,6): Expecting a (
*** Error 43 "SkyMilCtrl.c" Line 464(7,8): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 464(8,9): Expecting a declaration
*** Error 48 "SkyMilCtrl.c" Line 464(9,10): Expecting a (
*** Error 48 "SkyMilCtrl.c" Line 464(12,18): Expecting a (
*** Error 48 "SkyMilCtrl.c" Line 464(19,20): Expecting a (
*** Error 43 "SkyMilCtrl.c" Line 464(22,23): Expecting a declaration
*** Error 12 "SkyMilCtrl.c" Line 465(10,11): Undefined identifier x
*** Error 43 "SkyMilCtrl.c" Line 465(12,13): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 465(13,14): Expecting a declaration
*** Error 48 "SkyMilCtrl.c" Line 466(8,14): Expecting a (
*** Error 43 "SkyMilCtrl.c" Line 466(10,11): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 466(11,12): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 467(1,2): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 631(11,12): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 631(12,13): Expecting a declaration
*** Error 43 "SkyMilCtrl.c" Line 633(1,2): Expecting a declaration
1592 Errors, 1 Warnings.
Skipping link step. Not all sources built successfully.
BUILD FAILED
CCS start the error list from a line (464 as example) and
continue until the end of file ....
As example the line 464 is :
void resetLog(void)
int16 x;
--->464> for(x=0;x!=numLog;x++)
--->465> free(log[x]);
--->466> numLog = 0;
--->467>
If I change the positions of some functions (resetLog is shifted two function after ....) THE ERROR LIST DON'T CHANGE !!
If I try to compile this file using the command line method the ccs show me an error starting line 15 .... This error using the graphic environment is not showed !!
I tried on other computer and the problem is the same...
On a DELL Pentium IV 2.5GH with 512 RAM ....
The error list start at line 464 .....
___________________________
Original Post ID: 144514994
Re: Strange errors list ....
PostPosted: Tue Jun 03, 2003 12:48 pm     Reply with quote
:= One week ago I bought the PCH compiler....
:= I use it in a MPLAB ICD 2 environment with PICDEEM 2 PLUS.....
It's very common for a C compiler to dump out 1 million
errors if you are missing a brace, parenthesis, or semi-colon.
I suggest that you disable the display of "all errors"
and tell the compiler to show only 1 error.
Then, when it gives the line number with the error, start
looking at the code above that line. Look for the missing
brace, parenthesis or semi-colon.
Original Post ID: 144515010
