Harry Mueller
Posted: Mon Oct 24, 2005 2:10 pm |
Thanks guys, I've now put it in the main () and most of it works. I've got one issue though and I'd like to know why it's happening. Everything works perfectly until I try to print to the LCD, then then program stops working entirely. No servo, no IR, no LCD. I've also noticed that the LCD print statements add a lot of overhead...they almost triple the program length. Is this normal? Here is the code with the statements that cause the problem REMed out, near the end of the program
Thanks....Harry.
| Code: | //This program has a 1500 us pulse with 20 ms period as predicted.
//However, when the LCD print is enabled the program stops working.
//Not sure why at this point.
#include <16F628.h>
#fuses XT, NOWDT, NOPROTECT
#include <LCD_4LINE.c> //this file set up to use port B
#define quar_mov 250
#define GP2D02_VIN PIN_B3
#define GP2D02_VOUT PIN_A2
//Long delay function====================================
void long_delay_us(long count)
char i;
i = (char)(count >> 8);
while(i >= 1)
i--;
delay_us(253);
restart_wdt();
delay_us((char)count);
//Interrupt Service Routine (ISR)=========================
#int_TIMER0
void servo_isr()
//Position the servo(s)===================================
long quarter= 2;
long position;
set_timer0 (100);
position = quarter * quar_mov;
output_high(PIN_A0);
delay_ms(1);
long_delay_us(position);
output_low(PIN_A0);
main()
int reading=0;
int counter=9;
// lcd_init();
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_128);
//Collect the IR reading==================================
output_low(GP2D02_VIN); // start cycle with Vin low
delay_ms(1); // give the sensor a little time before we bug it
while (!input(GP2D02_VOUT)); //wait for Vout to go high
disable_interrupts(GLOBAL);
do {
delay_cycles(4); // minimum wait is 2us, max is 170us, 4 worked
output_low(GP2D02_VIN); // tell the sensor that we want a bit
delay_cycles(2); // might be as low as 1 (maybe), 2 worked
reading=reading<<1; // left shift the reading value
reading=reading|(input(GP2D02_VOUT)); // put the newest reading into the
// LSB of reading
output_high(GP2D02_VIN); // we read bit, and get ready for the next one
counter--;
} while (counter>0);
//LCD print statements====================================
// Program stops working if this is implemented
// lcd_gotoxy(1,1);
// printf(lcd_putc," IR Measurement");
// lcd_gotoxy(1,2);
// printf(lcd_putc,"================");
// lcd_gotoxy(1,3);
// printf(lcd_putc,"Value = %3u", reading);
// lcd_gotoxy(1,4);
// printf(lcd_putc,"Distance = ");
while(true);
Harry Mueller
Posted: Tue Oct 25, 2005 12:35 pm |
Anybody?
I'm trying to develop some servo code for a robotic hexapod and am having some problems. They would be a lot easier to debug if I had the LCD working.
Thanks.....Harry |
Posted: Tue Oct 25, 2005 12:42 pm |
| Quote: | #include <16F628.h>
#include <LCD_4LINE.c> //this file set up to use port B |
You're using Port B for the LCD. On the 16F628, pin B4 is the PGM pin.
If the chip is in LVP mode (and it is in that mode, as delivered from
the factory), then if you take pin B4 high, the chip will go into Low
Voltage Programming mode and give the appearance of a code lock-up.
Solution:
Add NOLVP to the end of your #fuses statement.
This will be the case for most PICs that you are likely to use. |
Harry Mueller
Posted: Tue Oct 25, 2005 2:07 pm |
Thanks PCM, that was it. As soon as I have some time I've got to get into the data sheets for the 16F628.
Harry |
