bootloading via USB
alecms
bootloading via USB
PostPosted: Mon Oct 24, 2005 4:10 pm     Reply with quote
Has anyone been able to bootload code to a PIC 18f4550 through the chips internal USB transceiver? If so, I would be very greatful if you could please give me an overview of how this is done.
Thanks,
Alec
asmallri
PostPosted: Mon Oct 24, 2005 6:39 pm     Reply with quote
Microchip have a bootloader for this chip on their site under USB solutions. Have you had a look at that one.
Regards, Andrew
alecms
PostPosted: Mon Oct 24, 2005 10:29 pm     Reply with quote
Thanks for the info. I looked at this but it seems as though this bootloader prevents one from using the USB port for anything besides updating firmware. I wonder if there are any more flexible solutions out there.
asmallri
PostPosted: Mon Oct 24, 2005 11:10 pm     Reply with quote
Well if you need it to do something else then you are not really looking for a bootloader. Once the bootloader has loaded a program it passes control to the user program and it can do what it likes with the USB port.
Regards, Andrew
alec
PostPosted: Tue Oct 25, 2005 3:20 am     Reply with quote
Have you been able to make this work? I suspect the difficulty would lie on the PC side. I don't see how you would switch from the dedicated bootloader USB driver provided by Microchip to another driver while the device is plugged in.
asmallri
PostPosted: Tue Oct 25, 2005 6:10 am     Reply with quote
I have not tried Microchip's implementation but cannot see a problem. It enumerates initialise as device X for the bootloading process, then at the end of the bootloading process it disconnects from the bus (optional) then reconnects and enumerates as a totally different device.
Regards, Andrew
alec
PostPosted: Tue Oct 25, 2005 11:54 am     Reply with quote
Thank for your help.
Alec
