Double Precision
Double Precision
PostPosted: Mon Jun 02, 2003 1:45 pm     Reply with quote
Is it possible to get double precision floating point math out of the 16F877 with the CCS compiler?
___________________________
Original Post ID: 144514972
Re: Double Precision
PostPosted: Mon Jun 02, 2003 6:35 pm     Reply with quote
:=Is it possible to get double precision floating point math out of the 16F877 with the CCS compiler?
The compiler only supports single precision (32 bits).
Original Post ID: 144514980
Steve H.
Use fixed point....
PostPosted: Mon Jun 02, 2003 6:36 pm     Reply with quote
You would have to write your own routines (Microchip may have a assembly library, I can't remember). You will be disappointed by the results and program size. Users don't tend to understand rounding errors that the limited precision floating point gives and you won't like it either. I'll wager a bet that most of us on this board use fixed point math, we place a decimal point in just for the user interface so that they think they are seeing floating point. All the actual work is done with int's or longs. The size and speed of your program will be very much smaller also.
OK sometimes I use floats with PIC's but only when I'm feeling cranky!
Regards,
Steve H.
Original Post ID: 144514981
