Problem with I2C and A/D
Goto page Previous  1, 2
Re: Problem with I2C and A/D
PostPosted: Fri Oct 21, 2005 5:18 am     Reply with quote
John Ilicitean wrote:
The I2c address is 1001 010X according to manual.
When I look at the TI datasheet for this device, it appears that the I2C address is hardwired into the chip. The available address range is from 1001 000 to 1001 111. A package marking indicate this 3 last bits by ADx.
Are you sure your chip address is really 1001 010 ?
John Ilicitean
PostPosted: Fri Oct 21, 2005 9:23 am     Reply with quote
Yes, I'm sure that my device is AD2, because it puts it on the chip.
Anyhow, i have tried all the possible address and it answers none the ADS1100
PostPosted: Sun Oct 23, 2005 5:32 pm     Reply with quote
This article in Circuit Cellar has a routine to read the ADS1100.
http://www.circuitcellar.com/fi2003/abstracts/F164abstract.pdf
They follow the data sheet exactly, and so they don't do a NACK
on the last read.
Here's the routine from that article:
unsigned int Measure_ADC(void)
BYTE temp;
unsigned int Result=0;
I2C_start();
I2C_write(0x91); // ADC address, then read
Result = I2C_read(1); // hi byte
Result = ((Result << 8) + I2C_read(1)); // lo byte
temp = I2C_read(1); // config register,
not used
I2C_stop();
return (Result);
Here is the routine after converting it to CCS, and
adding a demo program. Note that the ADS1100 does
not require initialization in order to use it. It comes
up in "continuous conversion" mode, upon power-up.
You can just start reading it.
#include <16F877.H>
#use RS232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define ADS1100_I2C_WRITE_ADDRESS 0x90
#define ADS1100_I2C_READ_ADDRESS  0x91
int16 read_ADS1100(void)
int8 temp;
int16 result=0;
i2c_start();
i2c_write(ADS1100_I2C_READ_ADDRESS);
result = i2c_read();                   // Read MSB
result = ((result << 8) + i2c_read()); // Read LSB
// Note: The data sheet shows an ACK on the last
// read, so that's what is done in the line below.
temp = i2c_read();    // Read Config register
// If you want to do a NACK on the last read, which
// is the normal method for i2c, then change the
// line above to this:
// temp = i2c_read(0);
i2c_stop();
return(result);       // Return 16-bit A/D result
main(void)
int16 adc_value;
// Read and display the A/D value every 1/2 second.
   adc_value = read_ADS1100();
   printf("Value read = %LX \n\r", adc_value);
If you still can't make it work after trying this code,
then I think you have a hardware problem.
Page 2 of 2
