SBS
| SPI Clock not working? |
Posted: Sun Oct 23, 2005 10:22 am |
I'm trying to set up an SPI port to communicate with an ADC. It doesn't appear to be working.
I am putting an oscillscope on the DO pin from the microcontroller and I am seeing a digital signal. However, when I put the oscilloscope on the clock pin, I see nothing.
Is there anything wrong with my code? The CCS help manual doesn't give ver much information about how the setup_spi command works.
Any suggestions?
Thanks,
Sal
#include <18F4620.h>
#define ADC_SELECT PIN_B1
#define ADC_DI PIN_C5
#define ADC_DO PIN_C4
#define ADC_CLK PIN_C3
void main() {
long int speed1;
long int speed2;
long int tempspeed;
BYTE data;
char display;
speed1 = 100;
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
while (TRUE) {
printf(" _ ");
output_high(PIN_B0);
delay_ms(speed1);
output_low(PIN_B0);
delay_ms(speed1);
data = 0xFA;
spi_write(0x40);
data = spi_read();
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
Posted: Sun Oct 23, 2005 10:39 am |
Where are you supplying the ADC with a chip select?
You may have to set the I/O direction to enable the SPI PINS. I do this by default but maybe the compiler does it automatically. _________________ Regards, Andrew
SBS
Posted: Sun Oct 23, 2005 11:10 am |
My ADC has its chip select tied low (active low).
I realized that I had my oscilloscope hooked up to the wrong signal. The ADC still isn't working yet, but now I have a better idea of what is going on.
With the code I posted, I am getting the correct digital output and the correct clock output pulses on the SPI_WRITE command. However, whenever I call SPI_READ, I do not see any clock pulses.
Any suggestions?
Thanks,
Sal |
Posted: Sun Oct 23, 2005 2:38 pm |
You won't see clock pulses with a normal read.
SPI, is a two way bus. When you write a byte, a byte is _simultaneously_ read back. the 'read' command, just retrieves this byte (though see below). Remember also that the byte read back, is the _last_ one presented by the slave. So if you have a slave that responds with a byte from a command, you have to go:
spi_write(COMMAND);
//At this point a garbage byte will have been read
//Check the data sheet for how long the slave needs to prepare
//the byte to return.
spi_write(DUMMY);
//Assuming the slave does not allw another transfer in this direction at
//the same time - clocks out the value 'dummy'.
rval=spi_read();
//Here you receive the byte that was clocked when the 'dummy'
//byte was written.
CCS, allows you to use the 'shortcut', of 'spi_read(DUMMY)', which clocks out the dummy value, and reads the byte returned. Unless a value is passed to 'read', no clock will occur however, ad the last byte transfered will be returned.
SBS
Posted: Sun Oct 23, 2005 4:24 pm |
Thanks for your help. I've almost got it working now. I can write to and read from my ADC. However, my ADC is not responding yet.
I've tried both SPI_L_TO_H and SPI_H_TO_L. Looking at the SPI registers I see that the SPI modes that this function sets are:
SPI_L_TO_H
CPK=0
CPE=0
SPI_H_TO_L
CPK=1
CPE=1
Looking in the PIC manual (PIC18F4620) I have 4 supported SPI modes. The setup_spi command only appears to be able to utilize two of them.
What I need is the mode of:
CPK=0
CPE=1
This exactly matches the timing diagram in my ADC manual. Can I set up this SPI MODE with the CCS command? Or do I need to directly set the registers to get this functionality?
Thanks,
Sal |
