enabling timer interrupt cause reset
Goto page 1, 2  Next
tophe59
PostPosted: Sun Oct 23, 2005 9:12 am     Reply with quote
When interrupt of timer1 is enable the mplab debuger stop and seam reset the program. (like watchdog timeout ??)
A breakpoint in the interrupt is never reached.
Help me please Crying or Very sad
#use delay (clock=40000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#int_timer1
   void timer1()
   SET_TIMER1(0xfe0b+get_timer1());
//main ...
   setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //init timer
   enable_interrupts(global);
PostPosted: Sun Oct 23, 2005 10:39 am     Reply with quote
Put the interrupt code, or a 'prototype' for it, in front of the main. Otherwise the compiler does not handle it right (remember a function must be defined _before_ it is used, and interrupts occur from inside the 'main', or it's subroutines.
tophe59
PostPosted: Sun Oct 23, 2005 10:49 am     Reply with quote
Thank's but the interrupt code is already before de main.
I change my first message.
Help again Crying or Very sad
PostPosted: Sun Oct 23, 2005 1:01 pm     Reply with quote
Your oscillator frequency is specified as 40 MHz.
I don't see the H4 fuse to enable the 4x PLL. You're using HS.
What PIC are you using ?
What hardware debugger are you using ?
What is the version of your compiler ?
tophe59
PostPosted: Sun Oct 23, 2005 11:47 pm     Reply with quote
my configuration:
- Pic 18f4620
- ICD2 + MPLAB 7.2
- 3.183
what is H4 fuse ?
PostPosted: Mon Oct 24, 2005 1:08 am     Reply with quote
what is H4 fuse ?
OK, you must be using an external 40 MHz oscillator.
Pic 18f4620
- ICD2 + MPLAB 7.2
- 3.183
I don't have PCH vs. 3.183, so I installed vs. 3.187. I found that
it doesn't have a 18F4620.H file. I also installed vs. 3.191 and it
doesn't have it either. These are slightly later versions than 3.183,
and if it was in that version, it should be in the later ones as well,
but it's not.
So I question how you can compile for 18F4620 with PCH vs. 3.183.
PostPosted: Mon Oct 24, 2005 1:31 am     Reply with quote
what is H4 fuse ?
A short explanation of the fuse names can be found in the file 'PICC\fuses.txt' in your compiler directory.
When using external crystals the following fuses are used:
- XT for frequencies up to 4MHz
- HS for the range 4 - 20MHz
- H4 for the 1(?) to 10MHz range with internal 4 x PLL multiplier (effective 4 - 40MHz).
When using external clock drivers (not crystals) you need other fuse settings but I'm too lazy so you have to figure that out yourself.
tophe59
PostPosted: Mon Oct 24, 2005 1:33 am     Reply with quote
I'm confused. I'm not use the same version at work and at home Embarassed
I have this problem with the 3.235. Excuse me Embarassed
I'm not using 4x Pll but a 40Mhz crystal
PostPosted: Mon Oct 24, 2005 2:14 am     Reply with quote
40MHz crystals are not supported.
The maximum crystal frequency you can use is 20MHz (with the HS fuse), for some models 25MHz. For higher frequencies use the H4 fuse with crystals up to 10MHz ( x 4 = 40MHz).
tophe59
PostPosted: Mon Oct 24, 2005 2:16 am     Reply with quote
i'm overclocking my 4620 ? Embarassed
asmallri
PostPosted: Mon Oct 24, 2005 2:18 am     Reply with quote
Yep - you need to use the PLL if you want to achieve 40MHz.
Regards, Andrew
tophe59
PostPosted: Mon Oct 24, 2005 2:29 am     Reply with quote
ok thank's ! How to use H4 fuse ? I must have 10 Mhz cristal ?
asmallri
PostPosted: Mon Oct 24, 2005 2:45 am     Reply with quote
Yes - if you want the PIC to run at 40MHz.
#fuses  H4
Regards, Andrew
tophe59
PostPosted: Mon Oct 24, 2005 10:01 am     Reply with quote
I have tested with 10MHz cristal and 10Mhz (40Mhz PLL) but not work Crying or Very sad
Always reset when timer interrupt enabled Confused
asmallri
PostPosted: Mon Oct 24, 2005 10:14 am     Reply with quote
Well your code shows ...
So I assume the test code is actually larger than you are showing.
Post the smallest code that actually demonstrates the problem.
A couple of alternatives for isolating the problem:
Manual Method A: with the small code, look at the list file produced, specifically around the interrupt handler and look at the code produced.
With tools: Set the debugger up to break in the interrupt handler and single step to see what happens
Regards, Andrew
Goto page 1, 2  Next
Page 1 of 2
