Controlling LCD flicker
Harry Mueller
PostPosted: Thu Oct 20, 2005 4:56 pm     Reply with quote
I've been playing around with a program that I cobbled together from various sources on the internet. It reads a digital rangefinder and outputs the value to an LCD.
The problem is that the LCD image flickers quite badly. Two changes I've made, based on what I've read in the archives, have had some effect.
1. Introducing a 1/2 second delay in the data refresh rate helped but still left a little flicker. I would prefer not to have any delay at all.
2. Moving the LCD_INIT () statement out with the WHILE(1) statement didn't help and it actually removed my first line on the LCD.
Here is a sample of the code; the relevent portion is in the bottom 20 lines.
#include <16F628.h>
#include <LCD_4LINE.c> //this file set up to use port B
#define GP2D02_VIN PIN_B3
#define GP2D02_VOUT PIN_A2
set_tris_a(0xff);
set_tris_b(0x00);
int reading;
int get_ir_reading();
   int counter=9;
   int reading=0;
   output_low(GP2D02_VIN);         // start cycle with Vin low
   delay_ms(1);                       // give the sensor a little time before we bug it
   while (!input(GP2D02_VOUT)); //wait for Vout to go high
   do {
      delay_cycles(4);    // minimum wait is 2us, max is 170us, 4 worked
      output_low(GP2D02_VIN);  // tell the sensor that we want a bit
      delay_cycles(2);         // might be as low as 1 (maybe), 2 worked
      reading=reading<<1;      // left shift the reading value
      reading=reading|(input(GP2D02_VOUT)); // put the newest reading into the
                                            // LSB of reading
      output_high(GP2D02_VIN); // we read bit, and get ready for the next one
      counter--;
      } while (counter>0);
      printf(lcd_putc,"\f IR Measurement");
      printf(lcd_putc,"\n================");
      lcd_gotoxy(1,3);
      printf(lcd_putc,"Value =%u",reading);
      lcd_gotoxy(1,4);
      printf(lcd_putc,"Distance =");
      return(reading);
while(true)
lcd_init();
get_ir_reading();
Any ideas on how I might be able to further reduce the flicker?
Thanks....Harry
PostPosted: Thu Oct 20, 2005 5:13 pm     Reply with quote
The reason it's flickering is because you're continuously clearing the
screen. You've got "\f" in there:
You shouldn't have to continuously re-init the LCD. If you have
to do that, then something is wrong.
Also your code as posted won't compile. You have a couple
floating set_tris statements.
Harry Mueller
PostPosted: Thu Oct 20, 2005 7:23 pm     Reply with quote
Thanks, that was the problem. I was also able to make the changes suggested in the archives. A couple of things:
1. It does compile. I don't know what floating set_tris statements are.
2. When the variable "Reading" goes under a hundred, the value displayed on the LCD goes to three digits. For example 99 becomes around 999, etc. I assume it has something to do with the bit shifting done withing the get_IR_reading function.
Here is the new code:
#include <16F628.h>
set_tris_a(0xff);
set_tris_b(0x00);
int reading;
   int counter=9;
   int reading=0;
   do {
                                            // LSB of reading
      counter--;
      lcd_gotoxy(1,1);
      printf(lcd_putc," IR Measurement");
      lcd_gotoxy(1,2);
      printf(lcd_putc,"================");
      lcd_gotoxy(1,3);
      lcd_gotoxy(1,4);
      return(reading);
lcd_init();
while(true)
get_ir_reading();
Thanks....Harry
PostPosted: Thu Oct 20, 2005 7:53 pm     Reply with quote
The two lines in bold are lines of code, they're not function prototypes.
They call CCS functions. They are not inside main() or any other
function. They cause the following errors when I try to compile the
program:
*** Error 28 Line 10(12,16): Expecting an identifier
*** Error 43 Line 10(17,18): Expecting a declaration
*** Error 28 Line 11(12,16): Expecting an identifier
*** Error 43 Line 11(17,18): Expecting a declaration
#include <16F628.h>
set_tris_a(0xff);
set_tris_b(0x00);
int reading;
Mark
PostPosted: Thu Oct 20, 2005 8:47 pm     Reply with quote
You aren't clearing the rest of the line so stale data is on the display.
Harry Mueller
PostPosted: Thu Oct 20, 2005 9:17 pm     Reply with quote
[quote="Mark"]
Ahhhh....thanks.How can I fix that? If I use a /f then the display flickers.
Harry Mueller
PostPosted: Thu Oct 20, 2005 9:20 pm     Reply with quote
program:
Does that mean that my compiler is not working properly and I should report this to CCS?
Harry
asmallri
PostPosted: Thu Oct 20, 2005 9:39 pm     Reply with quote
[quote="Harry Mueller"]
One way to to fix the field to a specific length
      lcd_gotoxy(1,3);
      printf(lcd_putc,"Value =%4u",reading);
Another way is to pad spaces at end
      lcd_gotoxy(1,3);
      printf(lcd_putc,"Value =%u   ",reading);
Another way is to clear the field first
      lcd_gotoxy(8,3);
      printf(lcd_putc,"      ");
      lcd_gotoxy(1,3);
Regards, Andrew
asmallri
PostPosted: Thu Oct 20, 2005 9:40 pm     Reply with quote
program:
Harry
If you can really compile the code you posted without errors then it is a bug.
Regards, Andrew
PostPosted: Thu Oct 20, 2005 10:10 pm     Reply with quote
You're not using the latest version of the compiler, so reporting a
bug on an older version won't do much good. Also, you're fairly
new. I would hold off on reporting bugs. Rather, look for other causes.
Harry Mueller
PostPosted: Fri Oct 21, 2005 8:44 am     Reply with quote
I'm going to pm you on this later.
Asmallri: Thanks a bunch, those suggestion were all better than the solution I came up with.
Cheers....Harry
