New CCS user with LCD problem
Goto page Previous  1, 2, 3
Harry Mueller
PostPosted: Wed Oct 19, 2005 11:15 am     Reply with quote
Now the test LED has stopped working on the 16F877 board so I think the chip may be fried.
I can program the code into it successfully and I thought that meant the chip was OK...I guess it's not. I seem to have "broken" 2 chips without knowing why.
Is there some kind of test that would definitively establish the health of the chip? Otherwise I guess I have to order a bunch.
Thanks...Harry
PostPosted: Wed Oct 19, 2005 11:58 am     Reply with quote
One issue is that you sometimes refer to using 16F877A and other times
to a 16F877. These chips are not interchangeable, and are different.
The 16F877A has a comparator module, which the 16F877 does not
have. They also have different programming algorithms.
Code that is compiled for one type should not be programmed into
the other. Also, your programmer must be set for the correct type.
People assume that the "A" chip is just a few minor fixes to the silicon,
but it's not. It's a distinct chip, by itself.
Harry Mueller
PostPosted: Wed Oct 19, 2005 12:28 pm     Reply with quote
Sorry, I've just got be more careful. The Mach X requires that I choose the correct microcontroller and the last two uCs that I used were both 16F877A's.
All my attempts to get the LCD going used that uC.
Thanks for pointing that out. Harry
Page 3 of 3
