no error but code crashed after one float variable defined
hundil
PostPosted: Tue Oct 18, 2005 8:40 am     Reply with quote
Hiiii everybody !...
Please help !!!
I am in trouble badly.
I have a code working perfectly on PIC18F452.
But, If I add (define) a float variable to the code,
My code is crashed.
My CCS ver is 3.203 (not bad I think)
No error messages.
The Compile is OK
Memory use is about %25 for ROM, %30 for RAM.
Any urgent help will be appreciated...
hundil
Mark
PostPosted: Tue Oct 18, 2005 8:55 am     Reply with quote
Could be a buffer overrun problem and adding the float exposes it.
hundil
added float prblem
PostPosted: Wed Oct 19, 2005 3:46 am     Reply with quote
thanks a lot for your opinion
but, what to do any more !...
hundil
asmallri
PostPosted: Wed Oct 19, 2005 4:25 am     Reply with quote
Are you using a bootloader? If so which one?
Regards, Andrew
hundil
PostPosted: Wed Oct 19, 2005 6:56 am     Reply with quote
No I am not...
hundil
Mark
PostPosted: Wed Oct 19, 2005 9:34 am     Reply with quote
How can we help when you haven't posted any code!
PostPosted: Wed Oct 19, 2005 4:26 pm     Reply with quote
Besides all the remarks of the people above I was triggered by the following:
Do you have a special reason for using this version? The early v3.20x versions have new optimized code for the PIC18 processors but were very unreliable. The first version I dared to try was v3.216. If you don't have access to the newer versions I suggest you revert to the stable v3.191.
