where is the mistake?
Goto page Previous  1, 2
PostPosted: Thu Oct 13, 2005 4:08 pm     Reply with quote
second program which you send only run led lamps but lcd is not work
I don't know. It works great for me. I'm using the same main()
code that you just posted. It says "savas" right on the LCD.
I have a question. In one of your previous posts, you show a
oscillator speed of 16 MHz. My PicDem2-Plus came with a 4 MHz
oscillator in the Y2 socket.
Are you sure you have a PicDem2-Plus ? Check the oscillator
package in location Y2 on the board. Is it really 16 MHz ?
treitmey
PostPosted: Thu Oct 13, 2005 4:16 pm     Reply with quote
Yes, Lower right corner of board. "PICDEM 2 PLUS DEMO BOARD"
I just changed Y2 to 16Mhz because that is what I use on my production boards.
Perhaps I hardcoded a delay? .....
sure enough,...I have a d_cycle defined and that changes with the clock.
I'll edit driver and note that d_cycle, may need to be adjusted to suit clock.
I changed to 4MhZ and retested.
retest still worked. Still don't know what isn't working.
Page 2 of 2
