do while timeout?
Goto page Previous  1, 2
PostPosted: Fri Oct 07, 2005 11:56 am     Reply with quote
I think most of your problems are caused by a mis-understanding
of data types and sizes.
The read_ext_eeprom() function only returns an 8-bit unsigned value.
You are expecting that it returns a 16 bit value. This is apparent
because you compare 'data' to 0x101. But look at the function
definition in your EEPROM driver file. The return value is a 'BYTE',
which is 8 bits. A byte value can only range from 0x00 to 0xFF, and
can never be equal to 0x101.
Also, you should know that in CCS, an 'int' is an 8-bit unsigned value.
It's the same as 'BYTE'.
BYTE read_ext_eeprom(long int address)
data = read_ext_eeprom (DATA_BLOCK_SIZE + (mem_pointer * 256));
mem_pointer++; '
if ( data == 0x101 )
edhaslam
PostPosted: Sat Oct 08, 2005 5:24 am     Reply with quote
mem_pointer++; '
Yes, admittedly the data test if (data == 0x101) is an error. I originally wrote the code for a 10-bit adc conversion but got the code around my neck a bit. This is a bit of legacy code from that. I thought i'd keep it simple this time by just having an 8-bit adc value to begin with, and get that working first. I'm still learning you know!
Ok, thanks for that.
So, where to go from here. Do I scrap the do/while loop. Go back to the for loop I had before and count the number of 'B' chars received or use receive interrupts? Please help as I'm a bit stuck!
Many thanks for your comments,
Ed
Page 2 of 2
