Oli Guest
| Clock switching? |
Posted: Tue Sep 27, 2005 7:28 am |
Hi
Im intending on using a PIC from the nanoWatt series - probably the pic16f684 or similar. I've been reading through the datasheet - I would like to use clock switching, as detailed on P26/27 of the datasheet. I would like it to idle using the LF clock, and then be able to switch to the HF clock upon demand. How do I go about doing this in CCS?
Any help appreciated, thanks! |
Oli Guest
| ...anyone? |
Posted: Mon Oct 03, 2005 2:42 am |
| Can anyone shed any light on this? pointers? |
Posted: Mon Oct 03, 2005 4:08 am |
setup_oscillator.
Basically, on parts supporting it, you setup the external oscillator, with the fuses statement, then use:
setup_oscillator(OSC_31KHZ);
#use_delay(CLOCK=31250)
To change to the low speed oscillator (and keep time delays correctly programmed).
setup_oscillator(OSC_NORMAL);
To switch back.
If you use any software time delays, remember that these are hard-coded, based on the last 'use_delay' statement, so if times need to be accurate, you will have to structure the program flow, to ensure that the correct use_delay, was the last one met, before a delay is used.
SherpaDoug
Posted: Mon Oct 03, 2005 4:00 pm |
Read the header file for the pic16f684 and see if there is reference to clock modes there. _________________ The search for better is endless. Instead simply find very good and get the job done. |
