sunyean
| PIC16F627A UART interrupt problems |
Posted: Sat Oct 01, 2005 10:01 am |
I am working with 16F627. I want to use a UART's receive interrupt and TIMER0 interrupt simultaneously. and use PORT B (PIN7~PIN5) as output.
I failed to operate them.
At first, when TIMER0 interrupt is active, UART interrupt does not work.
when I set the PORT direction using set_tris_b(), UART itself does not work. And disabled TIMER0 interrupt , UART interrupt works very well.
Anyway, I have to do trade-off coding for these codes. I really should use All these interrupt and PORT B as the same time.
What are problems here ?
#include <16f627a.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdio.h>
#define LIMIT 255
#fuses XT,NOWDT,NOBROWNOUT
#use delay (clock=4000000) // 발진주파수 = 4MHz
#use RS232(baud=9600, XMIT=PIN_B2,RCV=PIN_B1)
#int_rda
void int_rcv()
char c;
putc(c=getc());
#int_rtcc
void int_tmr0()
count ++;
set_rtcc(0xfe);
byte value = 0x00; // Port B의 제어값
byte RED = 0x00;
byte GREEN = 0x00;
byte BLUE = 0x00;
set_tris_b(0x00);
output_b(0x00);
setup_counters(RTCC_INTERNAL,RTCC_DIV_16); // Timer0 셋팅
enable_interrupts(INT_RTCC); // Timer interrupt 셋팅
enable_interrupts(INT_RDA);
set_rtcc(0xfe); // Timer0 초기값 설정
Posted: Sat Oct 01, 2005 11:50 am |
1. Add NOLVP to the #fuses statement.
#fuses XT,NOWDT,NOBROWNOUT, NOLVP
2. Add the ERRORS parameter to the #use rs232() statement.
#use RS232(baud=9600, XMIT=PIN_B2,RCV=PIN_B1, ERRORS)
3. Change the RTCC preload value so it doesn't interrupt at
such a high rate. With such a short interval between
interrupts, there is probably not enough time to process
the current interrupt before another one occurs.
Try setting it to:
set_rtcc(0x00);
Do that in both places in your code. |
Hans Wedemeyer
| try this |
Posted: Sat Oct 01, 2005 9:08 pm |
Try this.
TIMER0 is fast... Dop as PCMProgrammer says and adjust your timer to be somwhat slower!
Ths will work, if the incoming data stream has a small time dealy between each byte.
#include <stdio.h>
#include <stdlib.h>
#include <stdio.h>
#define LIMIT 255
#use delay (clock=4000000) // ????? = 4MHz
int count=0;
int RxFlag;
int RxData;
#byte RCREG = 0X1A
#int_rda
void int_rcv()
RxData=RCREG; // get byte and clear interrupt flag
RxFlag++; // tell the main loop something arrived...
// do NOT do this in the interrupt routine
// char c;
// putc(c=getc()); NO
#int_rtcc
void int_tmr0()
count ++;
set_rtcc(0xfe);
byte value = 0x00; // Port B? ???
byte RED = 0x00;
byte GREEN = 0x00;
byte BLUE = 0x00;
set_tris_b(0x00);
output_b(0x00);
setup_counters(RTCC_INTERNAL,RTCC_DIV_16); // Timer0 ??
enable_interrupts(INT_RTCC); // Timer interrupt ??
set_rtcc(0xfe); // Timer0 ??? ??
RxFlag=0;
if(RxFlag)
putc(RxData);
RxFlag=0;
sunyean
| not working |
Posted: Sun Oct 02, 2005 1:16 am |
still not working
#int_rda
void int_rcv()
// char c;
Follwing above code, I successed once, and then not worked.
umm, I thought TIMER0 is very short , that's why UART int is bothered ^^;
If I raise the clock, It can be solved ?
My source is about LED control that LED is blinking in regular (TIMER0) and sometime control signals(string) are received from PC.
When Blinking is good, UART is bad and UART good, blinking bad...
How can I solve this problem with 16F627 ?
I will try it agian with another PIC like 16F73. If the same problem happens, My code is wrong. If not, 16F627 must be not good MPU
Thank you two guys !! |
sunyean
| it's OK on PIC16F73 |
Posted: Sun Oct 02, 2005 4:19 am |
I tested the code which is modified for 16F73.
SUCCESS!!
Of course, As time value setted in TIMER0 is very large, UART must be working well. when time value is small, UART did not work also.
but, I adopted the same code to 16F627, even though time value is small, it's failded.
In conclusion, PIC16F627 has a weak point when TIMER0 and UART REV interrupts are used simultaneously.
If assembler, it may be OK ^^;
#include <16f73.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdio.h>
#define LIMIT 255
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, RESTART_WDT, BITS=8, ERRORS)
#int_rda
void int_rcv()
char c;
putc(c=getc());
#int_rtcc
void int_tmr0()
count ++;
set_rtcc(0x00); // ----------> [b]here, time value must be large (0~255)[/b]
setup_CCP1(CCP_OFF);
set_tris_b(0x00);
output_b(0x00);
set_tris_c(0xff);
if (count == 2)
output_b(0xFF);
output_b(0x00);
count = 0;
If you want to set a small time interval,
you need to use only UART interrupt, and use delay_us() or delay_ms() in the end of "while" roop |
