i2c master slave
Goto page Previous  1, 2, 3
aaaaamartin
PostPosted: Sat Oct 01, 2005 6:57 am     Reply with quote
latest compilers accept a baudrate setting, which is done in the master:
e.g.
#use I2C(master, fast=200000, sda=PIN_C4, scl=PIN_C5, FORCE_SW)
Further explained in the compilers readme.
Another thing I found out, if one uses the C-Version of AN734a, for the master, if I leave out all I2C_STOP (); commands it works fine.
If I use I2C_STOP, I continously get errors in the slave.
I don't know why this is, but so far I can live with it, as I have a sinlge-master system. In this case, I think, i2c_stop () is never needed.
Good luck
Martin
Mark
PostPosted: Sat Oct 01, 2005 7:18 am     Reply with quote
Why use slave & slow ?
Cause that's what you had. I just copied what you had and changed it a bit. I would use slow for the master. As I posted before, it is imposssible for you to recieve data that fast with the slave running at 4MHz.
Why and how use noclear here ?
Cause CCS doesn't clear the interrupt until the end of the routine. By doing it at the start, I have less chance of missing a byte.
Why dissable_interrupts in main (), you might loose data ?
I don't like to use variables that might change in an interrupt. What if you set port a to a value and before your main gets around to setting port a you start receiving a command to set port b. Then you might set port b to the port a value. The ints are not off for that long so typically wouldn't worry about missing a byte. You could also disable the ints, copy the values to temp variables and then turn back on ints and then process the temp variables.
Page 3 of 3
