How to stop the PWM and control its operation?
JimB
PostPosted: Wed Sep 28, 2005 12:04 am     Reply with quote
I put together the following to play with the PWM oscillator. I want to be able to have the PWM output only when the pushbutton is pressed ("0"). The while statement disables the start, but when the button is pushed the PWM output starts, but does not stop when released. I have single stepped through file and it does not stop at the while statement but goes down a line or two and then when it gets to the end, the debugger says it is running and the marker doesn't return. How does one stop the PWM output?
Also why doesn't the use of the PWM require anabling the PWM output pin?
#include <16F877A.h>
#device ICD=TRUE
#define output_high(PIN_A5)
#define PUSH_BUTTON PIN_A5
main()   {
         while(input(PUSH_BUTTON));
            setup_ccp1(CCP_PWM);
            setup_timer_2(T2_DIV_BY_1, 250, 1);
            set_pwm1_duty(125);
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Re: How to stop the PWM and control its operation?
PostPosted: Wed Sep 28, 2005 1:03 am     Reply with quote
I would try the following adjustments
#device ICD=TRUE
main()   {
            if (input(PUSH_BUTTON)) {
               set_pwm1_duty(125);
            else {
               set_pwm1_duty(0);
newguy
PostPosted: Wed Sep 28, 2005 1:04 am     Reply with quote
Think about it. When you push the button, your code sets up the PWM to run. Now that it's running, you release the button. Where is there code to a) recognize the button release, and b) turn off the PWM when the button is released?
Edit: whoops! You beat me to the answer by a minute!
What to do to cause a PWM to "stop"?
PostPosted: Wed Sep 28, 2005 9:35 am     Reply with quote
Thanks for the help. My problem was, I just didn't see a direct way to stop the output. Setting the duty cycle to "0" didn't pop into my head as a typical way to accomplish this. One would think that the compiler manual would address this issue. I was thinking that the PWM had no way to loop back to the original while() and was considering a go_to label as an approach.
So is the PWM a non typical operation that does not behave as other C functions that loop back through the code?
Also, why doesn't the CC1 output pin require an in or out declaration?
PostPosted: Wed Sep 28, 2005 2:13 pm     Reply with quote
Compile a test program and look at the .LST file to find the answer.
.................... setup_ccp1(CCP_PWM);
0016:  MOVLW  FF
0017:  MOVWF  21    // Set TrisC shadow register = all inputs
0018:  BCF    21.2  // Set RC2 pin = output (in the shadow reg)
0019:  MOVF   21,W  // Copy shadow register to W
001A:  BSF    03.5  // Bank 1
001B:  MOVWF  07    // Write shadow register to physical TRISC
001C:  BCF    03.5  // Bank 0
001D:  BCF    07.2  // Set CCP1 pin to a Logic Low level.
001E:  MOVLW  0C    // Configure CCP1CON register for PWM mode.
001F:  MOVWF  17
Answer: The CCS function inserts code to setup the TRIS correctly.
Mark
PostPosted: Wed Sep 28, 2005 2:15 pm     Reply with quote
Here's how I do it.
1. Setup the PWM
2. Make the pwm output and input
if button pressed
output
input
Joshua Lai
PostPosted: Thu Sep 29, 2005 12:01 am     Reply with quote
Like this can?
#device ICD=TRUE
short i;
main() {
if (input(PUSH_BUTTON)); {
set_pwm1_duty(125);
else {
set_tris_c(0x03);
i=input(PIN_C3);
[/quote]
JimB
Error with the "else" statement.
PostPosted: Thu Sep 29, 2005 1:09 am     Reply with quote
I cut and pasted the two examples above. When I compile them I always get an error highlighting the "else" word. The error message is
"A numeric expression must appear here." I just upgraded PCWH to version 3.235 with the same results.
Foppie
PostPosted: Thu Sep 29, 2005 1:12 am     Reply with quote
in this line:
the ; needs to go. so it will be
#device ICD=TRUE
short i;
main() {
set_pwm1_duty(125);
else {
set_tris_c(0x03);
i=input(PIN_C3);
JimB
PostPosted: Thu Sep 29, 2005 1:23 am     Reply with quote
Thanks all.
These lessons are sticking.
Mark
PostPosted: Thu Sep 29, 2005 6:17 am     Reply with quote
I have no idea why someone suggested that you do something with C3!
#device ICD=TRUE
int8 trisc;
#locate trisc = 0x87
  // Set up PWM
  set_pwm1_duty(125);
  // Make sure the PWM is off
  bit_clear(trisc, 2);
    // Turn on PWM
    // Turn off PWM
    bit_set(trisc, 2);
Joshua Lai
PostPosted: Sat Oct 01, 2005 12:26 am     Reply with quote
Oh, sorry, I used to look at 16F876 datasheet. Laughing
Mark
PostPosted: Sat Oct 01, 2005 6:56 am     Reply with quote
And on the 16F876 it is on C2 as well Razz
