General i2c question...
SBS
PostPosted: Tue Sep 27, 2005 9:43 pm     Reply with quote
From what I've read, you can have either a HW i2c or a SW i2c...
Can you have multiple i2c connections to other hardware with one PIC?
My application requires me to connect to an LCD display, AD converter and a Keypad. From what I've read, I can define an i2c protocal with #use i2c(...).
This can be set up to use the hardware i2c or a software (bit banging) i2c.
How can one set up two? One HW one SW?
Thanks,
Sal
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Sep 27, 2005 9:47 pm     Reply with quote
Why would you need two? Can't you hand all of your I2C devices on the same bus (be it h/w or s/w)? Do addresses conflict that badly?
SBS
PostPosted: Tue Sep 27, 2005 9:57 pm     Reply with quote
DOH! I knew that!
Thank!
asmallri
PostPosted: Tue Sep 27, 2005 10:40 pm     Reply with quote
You may want more than one bus if you are dealing with divices that support different bus speeds (such as 100K versus 400K) and you need to talk to one at high speed.
Regards, Andrew
Mark
PostPosted: Wed Sep 28, 2005 6:47 am     Reply with quote
Or say that you are talking between PICs with I2C and each PIC has its own external EEPROM.
treitmey
PostPosted: Wed Sep 28, 2005 8:18 am     Reply with quote
or 5V and 3.3V
and keep like devices together on a bridge
kender
PostPosted: Fri Oct 07, 2005 5:52 pm     Reply with quote
That's an interesting one. I wonder if it's possible to do this with just #use i2c(...) and without writing custom I2C bit-banging code?
Joshua Lai
PostPosted: Fri Oct 07, 2005 9:44 pm     Reply with quote
How to do that? How to specificy i2c speed in #use i2c(...)?
If not specify, what is the default i2c speed?
PostPosted: Sun Oct 09, 2005 2:04 pm     Reply with quote
You have an old version of the compiler. Your version (2.734) came
out in February 2001. The closest manual for that version is the
July 2001 manual. You can download it from one of these websites:
http://web.media.mit.edu/~earroyo/voice_chip/CCSC.pdf
http://www.robozes.com/otrosdoc/manualccsc.pdf
Then look in the #use i2c section of the manual to see how to set
the speed.
