Low frequency measurement
Goto page 1, 2  Next
OSUschap
PostPosted: Mon Sep 26, 2005 11:50 pm     Reply with quote
I am attempting to measure frequency with 16F876 or 877 using a 20 MHz crystal. The frequencies range from very low say 100Hz to a max around 3.5kHz. Since the frequencies are so low, a sampling time method would cause too much delay. My current plan is to use external edge triggered interupts and the standard timers (16 bit). I plan to use the timers to keep track of the constantly changing period of the incoming signal. Every time the trigger occurs, the frequency value would be updated and then the timer could be reset or left running I suppose. However, I do not plan on using any pre-scalers, and so my question is this. At the higher frequencies, will the interrupts be coming in too fast for the PIC to be able to perform other functions that may be needed, such as a pulse modulated output. Is this a really bad way of doing this, or does it sound solid at all? As I'm sure it shows, I do not have a lot of PIC experience so any replys will have to be at somewhat of a beginner level. Any suggestions or at least confirmation that this would work would be appreciated. Thanks
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Sep 27, 2005 12:17 am     Reply with quote
How much delay is too much? Say, your frequency of interest changes from 200Hz to 100Hz. How fast do you want to rect?
asmallri
Re: Low frequency measurement
PostPosted: Tue Sep 27, 2005 6:04 am     Reply with quote
OSUschap wrote:
I am attempting to measure frequency....
Not intending to be picky but this is not measuring frequency. Frequency is measured by counting the number of cycles (such as low to high transitions) that occur over a given period.
Regards, Andrew
sseidman
PostPosted: Tue Sep 27, 2005 6:52 am     Reply with quote
Measuring the period and taking it's reciprocal is most assuredly a valid way to measure frequency (by definition), as is counting cycles during a given period of time, as is taking the fft and looking for the peak, as is using a frequency-to-voltage converter and reading the voltage, and a slew of other methods that don't spring immediately to mind. Each method will have advantages and disadvantages, and be susceptible to different types of errors.
Scott
asmallri
PostPosted: Tue Sep 27, 2005 7:54 am     Reply with quote
Measuring the period and taking it's reciprocal is most assuredly a valid way to measure frequency (by definition). Scott
No. Neither is this the definition of frequency. Frequency is defined as the number of cycles per second. However the period method is a means of determining the frequency of a constant waveform. Consider for example a waveform with a mean period of 1ms but with a jitter of 100us. This wavform has a freqency of 1KHz. The result of measuring the cycle by cycle period would give you a varying frequency but with the same average frequency.
I did say I did not mean to be picky...
Regards, Andrew
cbrock
PostPosted: Tue Sep 27, 2005 9:45 am     Reply with quote
Check out this months Circuit Cellar. There is an article using the CCS compiler and a simple DSP algorithm.
OSUschap
PostPosted: Tue Sep 27, 2005 11:02 am     Reply with quote
Some delay is ok, but it needs to react in ms if not us. I cannot sample for so many seconds and count pulses there. However, if my output will simply continue to output the old data until the new calculations are complete, that would be desired.
Humberto
PostPosted: Tue Sep 27, 2005 12:01 pm     Reply with quote
OSUschap wrote:
You didnīt tell us the time the measuring signal takes to shift from 100Hz to 3500Hz.
For an incoming (assuming constant freq as asmallri well stated) signal of 100Hz
you need at least 10ms to get a measurable event.
If the signal is changing in frequency, you need another 10ms just to know that is changing.
The key is not to measure high frequency, (you can measure 50Mhz with a 20Mhz crystal)
the key is if the input frequency is stable enough at sampled times and the extra time
needed to do some task.
You would define this tradeoff before start coding.
Humberto
OSUschap
a look at what I'm trying
PostPosted: Tue Sep 27, 2005 1:46 pm     Reply with quote
The signal is one with constantly but slowly changing frequency. I understand that when waiting for an edge, I will have to wait 10 ms to get a frquency measurement for the worst case scenario (100Hz). However, this is probably well below what I will bet getting anyhow and if the frequency changed to such a value, the 10 ms would be an acceptable delay on the output as long as it didn't just go to 0 or something for that 10 ms. Here is what I started with, maybe it will give an idea of what I'm trying to do, although now that I've typed it, the code doesn't look quite right.
[/code]
//global variables:
long freq = 0.0;
#int_CCP2
CCP2_isr()
int period = CCP_2;
freq = 1/period;
set_timer1(0)
// Setup:
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // 200ns resolution
setup_ccp2(CCP_CAPTURE_RE); // interrupt on rising edge
enable_interrupts(INT_CCP2); // interrupt on CCP2 rising edge
enable_interrupts(global);
and then of course main will be doing other things
kender
PostPosted: Tue Sep 27, 2005 8:21 pm     Reply with quote
Initially I thought that you could sample the signal at a high rate for the amount of time less then one perion, do an FFT, and then look for the peak. If the signal is slow, there is plenty of time to do the FFT. Bu then I came to realize that the bin size will be big, and it can make the method not work.[/code]
OSUschap
code didn't work
PostPosted: Wed Sep 28, 2005 11:15 am     Reply with quote
Well, I wrote some code and you guys are probably not surprised that it didn't work. Can anybody tell me if I just made a rookie mistake or if this method is simply invalid? Thanks a lot for the tips guys, but I still have no idea if i'm approaching this in a reasonable way.
//global variables:
long freq = 0.0;
long period = 1;
#int_CCP2
CCP2_isr(){
   period = (CCP_2*0.0000002);
   freq = (1/period);
   set_timer1(0);
   // Setup:
   enable_interrupts(INT_CCP2);               // interrupt on CCP2 rising edge pin_c1
   while (true){
      if (freq <400)
         output_high(pin_b0);
      else if (400<freq<1500)
         output_high(pin_b1);
      else if (1500<freq<3000)
         output_high(pin_b2);
sseidman
PostPosted: Wed Sep 28, 2005 11:30 am     Reply with quote
Have you considered using a Frequency to Voltage converter like the AD650?
Mark
PostPosted: Wed Sep 28, 2005 1:44 pm     Reply with quote
Dividing CCP_2 by 5 million? CCP_2 is a 16 bit number that can't exceed 65535.
It would have to be a float and you wouldn't want to do that. Just figure out what the CCP values would be and use those in your if statements. Also, you probably want to turn off the other LEDs when you turn on one. Otherwise, they might all be lite at once.
PostPosted: Wed Sep 28, 2005 1:54 pm     Reply with quote
#int_CCP2
CCP2_isr(){
freq = (1/period);
set_timer1(0);
http://www.ccsinfo.com/forum/viewtopic.php?t=17806
Mark
PostPosted: Wed Sep 28, 2005 2:13 pm     Reply with quote
PCM programmer wrote:
#int_CCP2
CCP2_isr(){
freq = (1/period);
set_timer1(0);
Actually, 65535 at 20ns resolution would allow a 76Hz signal to be read so he doesn't really need to extend the resolution unless he wants to measure less than say 80Hz. Also, there is a mode for the CCP that will automatically reset timer1 to prevent latency problems.
Goto page 1, 2  Next
Page 1 of 2
