Joined: 18 Jul 2004 Posts: 40 Location: San Carlos, CA.
Posted: Mon Sep 26, 2005 12:42 pm
Mark said;
I've etched them in the Kitchen sink before in a glass tray of course.
I'm going to assume that you are single because the last time I tried that I got in big trouble with the wife. I have also used the oven to pre-soak surface mount boards before soldering or de-soldering the parts and using the dishwasher to wash the boards after soldering, both with similar domestic results. Prototyping was much simpler when I was single.
- Bruce
Mark
Posted: Mon Sep 26, 2005 1:29 pm
I wear the pants ;)
rnielsen
Posted: Mon Sep 26, 2005 4:32 pm
I wear the pants ;)
Only when your wife lets you. lol
Actually, I've designed circuits for years using those white proto-board setups. I usually use the ones that have multiple modules mounted on a metal back.
I like to use this method because it's easy to make changes and once I get a project working like I want then I use the technique, that can be found at http://www.pulsar.gs/PCB/a_Pages/1_Menu/Overview.html to make a nice PCBoard. Double sided boards can be a bit tricky but if you place markers on each side and line them up properly the board can come out just fine.
Page 2 of 2
