IO Problem, Cannot Read Inputs
PostPosted: Tue Sep 20, 2005 1:45 pm     Reply with quote
Im not sure what the problem is, but I cannot seem to read my IO pins.
I am using the PIC18F8490. I have an LCD connected (which I know works). I am just trying to change whats displayed to corresond to switch settings. It never changes. I have external pullups on all of the input pins. Any ideas?
#include "lcdboard.h"
   PreLaunch();
   Configure_IO();
   Configure_Units();   // Read all switch setting, set defaults
   while(1){
      testIO();
void PreLaunch(){
   setup_oscillator(OSC_31KHZ|OSC_INTRC);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   setup_vref(FALSE);
   setup_spi(SPI_SLAVE);
   setup_low_volt_detect(FALSE);
   setup_lcd(0b10001001,0b01110000);
void Configure_IO() {
   Set_TRIS_B(0x00);
   Set_TRIS_C(0x00);
void TestIO(){
   int value1 = 0;
   int value2 = 0;
   if (DIP1 == 0)
      value1+=1;
   if (DIP2 == 0)
      value1+=2;
   if (DIP3 == 0)
      value1+=4;
   if (DIP4 == 0)
      value1+=8;
   if (DIP5 == 0)
      value1+=16;
   if (DIP6 == 0)
      value1+=32;
   if (value1 > 29){
      lcd_symbol(Digit_Map[3],DIGIT5);
      lcd_symbol(Digit_Map[value1-30],DIGIT4);
   else if (value1 > 19){
      lcd_symbol(Digit_Map[2],DIGIT5);
      lcd_symbol(Digit_Map[value1-20],DIGIT4);
   else if (value1 > 9){
      lcd_symbol(Digit_Map[1],DIGIT5);
      lcd_symbol(Digit_Map[value1-10],DIGIT4);
   else {
      lcd_symbol(Digit_Map[value1],DIGIT4);
   if (SW1 == 0)
      lcd_symbol(Digit_Map[1],DIGIT8);
   if (SW2 == 0)
      lcd_symbol(Digit_Map[2],DIGIT8);
   if (SW3 == 0)
Heres part of the .h file
#include <18F8490.h>
#device adc=10
#FUSES NOWDT                    //Watch Dog Timer uses 1:32 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV28                   //Brownout reset at 2.8V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOMCLR                 //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=32000)
#define SW1 PIN_B7
#define SW2 PIN_B6
#define SW3 PIN_B5
#define DIP1 PIN_B0
#define DIP2 PIN_B1
#define DIP3 PIN_B2
#define DIP4 PIN_B3
#define DIP5 PIN_B4
#define DIP6 PIN_C2
newguy
PostPosted: Tue Sep 20, 2005 1:52 pm     Reply with quote
You have the tris set wrong. 0 = output, 1 = input.
Mark
PostPosted: Tue Sep 20, 2005 1:59 pm     Reply with quote
PIN_B7 is #defined as a number
#define PIN_B7  31759
that means something to CCS specific functions.
In your code:
   if (DIP1 == 0)
would be
if (31759 == 0)
See the problem yet? You need to define DIP1 as portb.7 where you define portb as a variabe at the location of portb. Another option is to use the CCS function input(DIP1).
Also, if you handle the var yourself, remember to set the tris correctly (1 for an input). If you use standard_io and the CCS function, the Compiler will handle the tris for you.
PostPosted: Tue Sep 20, 2005 2:29 pm     Reply with quote
Thanks Guys, works now.
